NEW U7137 UPDATE..
gergregg
Re: RE: Re: RE: NEW U7137 UPDATE..
Post by gergregg »
TooCoolHemi wrote:When loading the 93oct. tune i have tcm option's.Any change's you want to make to the tcm have to be made at this time.Once it's loaded into the truck and go to load my custom tune i have no tcm option's.If i want to make any tcm change's i have to go back to stock and reload the 93oct. tune.This is very time consuming and pain to want to make any tcm adjustment's
X2 I have the same problem when dealing with custom tunes. I also lost my cruise above 60
gergregg
Post by gergregg »
Double post
TooCoolHemi
RE: Re: RE: Re: RE: NEW U7137 UPDATE..
Post by TooCoolHemi »
Thank's for the info Greg.I haven't had a need to use cruise control but mine's probably doing the same.(i'll have to check it) I hope Johan has it fixed in the next up date.Being i change most of the shift schulde and it get's reset everytime you go back to stock it take's awhile to do.So i'm waiting for the fix instead of spending hour's going back to stock trying to get it where i want it.(To much trouble to even mess with it this way)
my05hammer
Just installed 9r09e
Post by my05hammer »
Just installed the new update yesterday in my 2010 Ram 1500 QC 4X2 and took it out for a test drive today. I have a CAI, Fastman TB, straight pipes, catch can, 4.10 gear, and the 93 oct tune (Throttle sensitivity is at 20% but I might bring that back to 0%).
When I first took it out after the update it was not warmed up yet and I goosed it a couple of times. The pinging was pretty bad. Once it warmed up the pinging calmed down quite a bit but didn't completely go away. Is this normal after an update or reset and will it eventually "learn" and eliminate the pinging?
Also, I had a CMR tune made for it 2 weeks ago with revision 9r08. If I reinstall the CMR tune with the update (9r09e) installed in the Predator, will the CMR tune be updated also when I reinstall it?
RE: Just installed 9r09e
Yes, the tune will work.
Do some logging after a day or two and let us know.
my05hammer
Re: RE: Just installed 9r09e
mikel wrote:Yes, the tune will work.
I sent the CMR tune to you to shut off a couple things for the drag strip, when I get it back from you I will download it and start logging.
Thanks.
08Hemi3542
RE: Re: RE: Just installed 9r09e
Post by 08Hemi3542 »
I noticed a couple posts re: Jeep WK's not being able to update tire size. this was one my main reasons for buying this unit. I have an 08 WK with the 5.7L. Please advise when this will be fixed...thanks in advance. I also started a thread about this so a response in either one will work!
Edit - I just noticed I posted in the predator section...I have a Trinity so I have posted in that section as well
airportdave
Re: RE: Re: RE: Just installed 9r09e
Post by airportdave »
08Hemi3542 wrote:I noticed a couple posts re: Jeep WK's not being able to update tire size. this was one my main reasons for buying this unit. I have an 08 WK with the 5.7L. Please advise when this will be fixed...thanks in advance. I also started a thread about this so a response in either one will work!
Several of us 08-10 WK owners with Predators also waiting for this fix...
http://diablosport.com/index.php?name=P ... ic&t=25837
2010 Jeep Grand Cherokee Limited 5.7L, QDII
InTune 91 Octane Tune
(Previous Predator User)
RE: Re: RE: Re: RE: Just installed 9r09e
We are looking into it guys.
airportdave
Thanks Mike- looking forward to a correct speedo and trip/fuel computer.
Chuck1026
Post by Chuck1026 »
Regarding WK & XK speedometer adjustment with the U7137... DO NOT HOLD YOUR BREATH.
I purchase the unit in spring/summer 2010 for my 2010 XK and it did not allow speedometer / tire calibration. Mike said, "hang on, we're working on it"... well, I sent the unit back.
I was just checking to see if it had been resolved, but I guess not. Bummer... I really want a programmer but I want all of the listed features to function.
white_lightning
Post by white_lightning »
TooCoolHemi wrote: i change most of the shift schulde and it get's reset everytime you go back to stock it take's awhile to do.So i'm waiting for the fix instead of spending hour's going back to stock trying to get it where i want it.(To much trouble to even mess with it this way)
getting a custom TCM tune with your shift schedule written into it would fix that.
I have DCX CMR and am working on a TCM tune for my '05 Hemi Ram. got firmer shifts, less TM than canned tune, altered part-throttle shifts, 6,200 rpm WOT shifts.
load custom TCM tune, shifts are done. no more setting shift points in "modify tune" with the tuner.
definately a p.i.t.a. to re-do shifts after tuning to stock. I used hate changing Croms because it took a while to re-program my shifts before I had a custom TCM tune. timed a couple Crom changes before my custom TCM tune: 50 minutes on one, 55 minutes for another. total waste of time unless the Crom had more features or better tunes than the previous Crom.
I will start a thread here in the Predator section about my progress in a week or two. hope to have some TCM tunes ready for sale in a month or 2.
sanitarium16
Post by sanitarium16 »
Is the speedometer correct with stock rims/tires? even though you can not set it?
lumpy69
Post by lumpy69 »
Nobody seems to care about the loss of cruise control after 60mph that some of us are dealing with.
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
butch1581
Post by butch1581 »
lumpy69 wrote:Nobody seems to care about the loss of cruise control after 60mph that some of us are dealing with.
I had this issue a while back and it ended up being a bad front wheel speed sensor. Nothing to do with the Diablo. Just something to check...
2006 Dodge Ram 5.7 Hemi
Predator
V.9r11
Custom tune from Procharger
