You did install the USB-Serial device driver correct?
Your tool info looks fine. I tried same CROM rev with a bench ECU taking it's backup and exporting it from Predator.
It downloaded using DSDL using Prolific USB-Serial driver and cable (U7778) without issue. This was on PC running XP Professional.
Might want to try eliminating other USB devices and plugging your USB-Serial adaptor direct into PC/Laptop.
Also, I assume your using DSDL "Express Tune Tab" -> "Get Tune File from Tool" button.
BACKUP ORIGINAL
RE: BACKUP ORIGINAL
RE: BACKUP ORIGINAL
jimb---- Success I was using a belkin powered multi usb connector unhooked it plugged direct to hispeed usb port where belkin was and hey presto backup saved
thankyou for all your help
mick
mick
my other car
RE: BACKUP ORIGINAL
Ahhh... You were connected to a USB Hub? Good to hear you got it working!
