NEW U7137 UPDATE..
butch1581
Re: RE: NEW U7137 UPDATE..
Post by butch1581 »
white_lightning wrote:
TooCoolHemi wrote: i change most of the shift schulde and it get's reset everytime you go back to stock it take's awhile to do.So i'm waiting for the fix instead of spending hour's going back to stock trying to get it where i want it.(To much trouble to even mess with it this way)
getting a custom TCM tune with your shift schedule written into it would fix that.
I have DCX CMR and am working on a TCM tune for my '05 Hemi Ram. got firmer shifts, less TM than canned tune, altered part-throttle shifts, 6,200 rpm WOT shifts.
load custom TCM tune, shifts are done. no more setting shift points in "modify tune" with the tuner.
definately a p.i.t.a. to re-do shifts after tuning to stock. I used hate changing Croms because it took a while to re-program my shifts before I had a custom TCM tune. timed a couple Crom changes before my custom TCM tune: 50 minutes on one, 55 minutes for another. total waste of time unless the Crom had more features or better tunes than the previous Crom.
I will start a thread here in the Predator section about my progress in a week or two. hope to have some TCM tunes ready for sale in a month or 2.
Where did you get your custom TCM tune. I need one bad too. Mine downshifts way too easy when towing and the torque convertor unlocks so easily. I am going to look locally for a place that does custom tunes.
2006 Dodge Ram 5.7 Hemi
Predator
V.9r11
Custom tune from Procharger
lumpy69
Post by lumpy69 »
Went to the dealer a while back and did a scan,no codes.
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
lumpy69
Post by lumpy69 »
butch1581 wrote:
lumpy69 wrote:Nobody seems to care about the loss of cruise control after 60mph that some of us are dealing with.
I had this issue a while back and it ended up being a bad front wheel speed sensor. Nothing to do with the Diablo. Just something to check...
2004 Ram 1500 4x4
3" lift in front
1.5" in rear
cold air intake
315/70/17 Mudders
Diablo U7137
MBRP Cat Back Duals
456 Gears
white_lightning
Post by white_lightning »
got my custom TCM tune from myself. I have Diablo CMR software, so am a CMR tuner. hope to have some truck TCM tunes worked out to sell in the near future.
