Throttle lag
Throttle lag
I have a 7137 on a 2010 ram hemi and just curious as to if this tune rewrite is different from the throttle sensitivity adjustment in the canned tune?
RE: Throttle lag
If you are seeing that adjustable parameter, yes. We change this in the tunes already, but there is room for more sensitivity if you desire.
Throttle response
I think I have attached the last tune written, would you please send me the file with more throttle sensitivity and also check to see if you can take out any more torque management.
- PCM_05187935AD_Perf_93oct_modified.drg
- (5.25 KiB) Downloaded 268 times
RE: Throttle response
Hey Mike, were you able to do anything about my request?
Have you tried adjusting it yourself?
You have the parameter, no need to be loading tunes.....
- white_lightning
Re: RE: Re: RE: Throttle lag
you ever get the trans tune to load? I have an '05 truck too, and have been able to load custom trans tunes. there are a couple tricks to getting a custom trans tune to load in an '05.silverdaytona wrote:Tried to load the files you sent me yesterday, again this morning and the message it gave me was Problem with Custom Tune 05094258ad wont be used. ad is the trans part of the tune.
silverdaytona
RE: Re: RE: Re: RE: Throttle lag
No,I just loaded the PCM part and that worked pretty damn good. What are the couple of tricks that you are talking about?
- white_lightning
Re: RE: Re: RE: Re: RE: Throttle lag
I will PM you about the tricks.silverdaytona wrote:No,I just loaded the PCM part and that worked pretty damn good. What are the couple of tricks that you are talking about?
Throttle response increase
I just purchased a predtor u7136 for my 07 charger sxt. i am currently running revision v.9r06. can you please modify my last written tune to increase my throttle response. thanks alot.
- PCM_05094911AI_Perf_93oct.drg
- (4.25 KiB) Downloaded 219 times
I also would like to get rid of my throttle lag. I have a Predator u7136 for my 05 3.5L 4 speed magnum. I run the 91 tune with the 9r01 since i got it way back then. How would i go about doing this? At first when i reload the 91 tune it seems to run great but act like it goes back to a stock tune so every month i go back to stock and reload the 91 tune just so it feels like it not a stock feeling.
Hope this makes some sense
Thanks.
Thanks.
I just purchased a predtor u7136 for my 07 charger sxt. i am currently running revision v.9r06. I am currently not abke to adjust throttle sensitivity. Attached is my last written tune. can you please modify my last written tune to increase my throttle response. thanks alot.mikel wrote:there is already an increase in response in the canned tunes, if you want more, export and post your last tune written.
- (4.25 KiB) Downloaded 287 times
here you go
- pcm_05094911ai_throttle.drg
- (64.63 KiB) Downloaded 206 times
I just purchased a Predator u7136 for a 2010 Challenger SE. Attached is my last written tune. Can you please modify my last written tune to increase my throttle response. Thanks alot.
- 68054123AC_custom.drg
- (3.25 KiB) Downloaded 234 times
what do you need to fix my throttle responce. i have a 7135 with perf.91 tune and i have the mds shut off,that it,no other changes it is a challenger 5.7 auto 2010 with flowmaster exhaust ,all stock.
throttle feels washy. and shifts 1-2 and 2-3 toooo soon, even under a load. sounds and feels like a dog. can you help?
hope you can help,.
hope you can help,.
