Trinity docking pins damaged
General Trinity Support
GeeTeePT
Post by GeeTeePT »
Trinity T 1000,latest crom, /05 PT GT.
Went to plug in my OB2 cable to the Trinity and it wouldn't boot up. Tried a couple of more times with the same result. Brought the unit in and connected up to my PC with the USB cable...no problem with booting or display. Using a mini flashlight I checked the docking port on the Trinity for the OB2 cable and sure enough that's were the problem is. On the far right one pin connection point appears to be pushed back and the one just left to that is bent and lifted. In short the pin housing looks buggered. I also wonder if there is a problem with the OB2 cable which led to this . So the next are obvious Q's ...is it repairable or replaceable under warranty? Unit is aprox. 6 mths old and purchased from Mopac. By the way... just recently installed the 93 oct tune onto my S1 PCM and am in the middle of tuning the car for STknock etc. ... HELP!!!
RE: Trinity docking pins damaged
Please fill out the rma request and get it in for repairs asap.
GeeTeePT
Post by GeeTeePT »
Thanx...sent form and waiting for confirmation. Guess I should just take the OB2 cable back to the dealer, show them the Trinity and explain what's happening, and hopefully they will do a swap.
05PT GT. Limited Trim. K&N CAI. Needswings 3" O2 & Downpipe & High Flow CAT to 2.5" Magnaflow exhaust. Plastic manifold.Trinity 93 oct tune. Dual pod pillar with AM Sport Comp boost and Innovate AFR wideband gauges. S1 PCM & injectors.
sethm3customs
Post by sethm3customs »
ok mine has the exact same problem. my pins are bent back. unit will not come on and i have the tune on my truck, i need to be able to take the tune off, will this cost me anything besides shipping to get this repaired?
Seth Nelson
Owner of M3 Customs
2007 GMC Yukon Denali w/ 2/4 drop and 24 inch boss wheels
GeeTeePT
Post by GeeTeePT »
First check to see if your unit is still under warranty. The guys from DS were really quick with my unit .
07rado
Post by 07rado »
same..bent pins..wont come on...all that stuff.
GeeTeePT
Post by GeeTeePT »
Just wanted to say thanks , pass it on if you will, to the guys at the shop for the quick repair and return on my Trinity unit. It is once again working fine and with the fuel I have added this week the PT is now out of the danger zone. The stknock has dropped to -1 degree at 10.22psi boost which is still not WOT. Even more than that ....she freakin pulls great. Hope you all had a Merry Christmas.
OnkelMatze
Post by OnkelMatze »
same problem here, two pins are damaged, no power-up in the car...
seems like that is a common problem for the trinity
gizmodo
Post by gizmodo »
I try to unplug the Trinity as infrequently as possible to prevent this kind of thing.
Vas@Diablosport
Post by Vas@Diablosport »
if you are having these issues, just fill out an RMA request form and get the tool sent in to us, repairs will be made under warranty.
No, i don't work here.
OnkelMatze
great support!!
just sent my Trinity from Germany to Florida
GeeTeePT
Post by GeeTeePT »
OnkelMatze wrote:great support!!
...are you getting any air miles with that ? :D
Return to “General Trinity”
