03 Tune loading problem
BBO
Post by BBO »
i have a 03 dodge 3500, bought a predator used. Tried to load the program and it said vehicle on in database. then it said something about cal id. Please help.
BBO
RE: 03 Tune loading problem
Post by BBO »
no help?
03 3500
ropnjessi
Re: RE: 03 Tune loading problem
Post by ropnjessi »
BBO wrote:no help?
You probably need to update to the latest CROM file:
http://www.diablosport.com/index.php?mo ... lay&pid=73
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
BBO
RE: Re: RE: 03 Tune loading problem
Post by BBO »
i didnt receive the pc interface kit with it. I was told i could go to radio shack and pick up the cable, is this true, or do i have to order the expensive kit? I dont want to have to spend $50 on a kit and it not even solve my problem.
ropnjessi
Re: RE: Re: RE: 03 Tune loading problem
Post by ropnjessi »
BBO wrote:i didnt receive the pc interface kit with it. I was told i could go to radio shack and pick up the cable, is this true, or do i have to order the expensive kit? I dont want to have to spend $50 on a kit and it not even solve my problem.
True story.....
BBO
RE: Re: RE: Re: RE: 03 Tune loading problem
Post by BBO »
This is a PITA.
i found one on amazon for $30, ill just order it from there. Unless it is cheaper at radio shack? Are you sure that i just need to update the predator and it should work?
duallydave
Post by duallydave »
i found the adapter cable at london drugs for about 10buks,try staples too.cheap cables there,if he didnt put it bak to stok before selling to u u may have a prob
