error message.
johnc
RE: Re: RE: error message.
Post by johnc »
Please try DSDownloader 1.9.5.4.
This version has much longer timeouts when trying to contact the server, so it may work for you. If not, it may provide more detailed information in the error message.
Thanks, and let me know what you find.
johnc <at> diablosport.com
Jected
Post by Jected »
Ok trying it now.
07 300C SRT8
RDP built 426/RDP-Bullet/Harrop supercharger(Boost 20psi)/HP/F custom fuel &Intercooler system/Nitrous setup/DSS 1000hp Half Shafts/Kooks Headers/Zoomers cat back/Precision Industries 3200
Jected
Post by Jected »
No luck mate. Same error as before although no code 2 error.
07 300C SRT8
johnc
Post by johnc »
Instead of (code 2) it should say something in the parenthesis. If you do not see the parenthesis then it makes me wonder if there are now multiple versions of DSDownloader installed on your machine? Check the help dialog and make sure you are running 1.9.5.4 each time.
Jected
Post by Jected »
You don't just have a file to download similar to the CROM update version file or is the an FTP server address I can get it from, directly.
07 300C SRT8
Jected
Post by Jected »
Each DSDownloaded was uninstalled before loading the ones you asked.
This is what version I am running as per Help/About.
Pred probs4.jpg (68.52 KiB) Viewed 3824 times
Jected
Post by Jected »
Jon I need to head off now.
Hopefully you have some good news for me in the morning.
Thanks for your assistance so far and I will check back in the morning.
Daniel.
07 300C SRT8
johnc
Post by johnc »
Ok. I think Mike is going to PM you next time you are available and set something up.
johnc
Post by johnc »
06nightrunner, I also would be interested to know if this worked for you any.
It seems that these Aussie cars have European calibration IDs which are not currently supported.
We are looking into what can be done about this.
Jected
Post by Jected »
Your kidding....how long will this take to sort.
07 300C SRT8
Jected
Post by Jected »
It also does not explain why some people in the states are having the same problem. Are you sure this is right????
07 300C SRT8
06nightrunner
Post by 06nightrunner »
still the same error message
Jected
Post by Jected »
Yeah it has to be a connection error. The problem with this is that the DSDownloader isn't even allowing us to connect to begin any download. The error comes up straight away without downloading anything.
07 300C SRT8
06nightrunner
yeah i dont know anymore im so dissapoint in this right now its not funny. as of right now its a $400 paper weight. I need this to work by this weekend i got time trials at the strip.
