How can I get the new updates?
My pred won't take the new update, but I want the fuel pressure/injector parameters? Johan can I get this tune please?
07 Chevy, LBZ crew cab, LT-2.
Performance Exhaust.
Moto Metal, Skulls
285/70/17" BFG, KO's
Moto Metal, Skulls
RE: How can I get the new updates?
Thats not a tune, they are adjustable parameters.
How long have you owned the tool?
I know, I wan't the tune. Mike, I'm Cody, I emailed you. How do I get this tool to except the tune with those parameters?
Moto Metal, Skulls
Moto Metal, Skulls
A guy on here sent me r9t12e, but still say the same thing, can't find flash download
Moto Metal, Skulls
Moto Metal, Skulls
older tools will not take that crom.....
Thats great! Any chance I can get a custom tune then?
Moto Metal, Skulls
Moto Metal, Skulls
Mike that is bologna you are feeding him crap , you sent me this crom ( r9t12e , with all the adjustments ) for a 7186 programmer when I was having all the problems with mine and it is loaded and still running fine. There is no reason for this gentleman to purchase a new tuner and you no that. You guys made the 7186 and supported the 2007 and need to keep it up. You need to get this gentleman taken care of and all the others like myself that bought a 7186 for the early model 2007. What are you trying to say that you guys supported it and all of a sudden your done with it. Well I no for a fact that I'm running the crom and can adj. timing and rail pressure. Just burns me up for you to have a file posted since August that will support the new vehicles but toast the old ones. If this is your word diablo has went completely down the tubes. If he does purchase a new programmer due to you not helping him out I sure hope it is with a different company
If not , have him send you his stock tune and make it work as you finally did mine. I would contact Mike he is probably the last of the good ones that really cares and will help you out, actually the tune 8/10 needs to be taken off and repaired to work with all 7186
2007 Gmc Duramax Allison 2500HD 4 wd 4 Door
Blocked and Fingered
Predator u7186
S & B Cold Air Intake
Damon
Predator u7186
Damon
Tell ya what it's misleading the Aug file states "lly lbz" , not 2010 and will not suopport the 7186 lbz
Release 9r12 (Support for 2010) 08-04-2010 9r12 u7186_dmx_lly_lbz-9r12.crom (1049k)
Predator u7186
Damon
Predator u7186
Damon
WOW!!!! Is this not true Mike?
Moto Metal, Skulls
Moto Metal, Skulls
What?
You guys are kinda taking this way off base.
The 9r08 update still works if you cant load the latest, so there is no way we just removed support for anything, period.
So there is no way, you can or have updated the older tools to except the the new tunes?
Moto Metal, Skulls
Moto Metal, Skulls
Can you give me a custom tune, that supports that injector timing?
Moto Metal, Skulls
Moto Metal, Skulls
Sorry Mike but I have the tune ( r9t12e )that you ( Mike ) emailed me after I had to send you my stock tune because of the same problems as LBZPWR. And yes as you no it does have adj. timing and rail pressure. My question is ? Why have you guys not put out the correct tune so that the ones like me with a early model 07 can have, what is the hold up ? You know it can be done and has been done, why are you guys not offering the support that you can so gentlemen like LBZPWR can have what he deserves and is available . If it can not be put on the 2010's tune then write the tune for the older models. This is very frustrating to see you guys handicap someone that has purchased your product and is now getting left behind. You guys use to be so awesome
Predator u7186
Damon
Predator u7186
Damon
Re: RE: How can I get the new updates?
" The 9r08 update still works if you cant load the latest "mikel wrote:What?
Off Base , what kind of poor support is that. The man is asking for the adj. rail pressure and timing and thats your answer ? What an answer why should he have to rum the 08 crom when you guys can and have written it to work with the older models , 2007, ( 4 year older models ) Thats bad business dude
Predator u7186
Damon
Predator u7186
Damon
RE: Re: RE: How can I get the new updates?
LBZPRR , look at the last reply on this post by me on " 9V11 is Junk Also " dated 7/21/10 . It can be done and has been done they are just not taking the time to do it
Predator u7186
Damon
Predator u7186
Damon
