lb7 predator-no boost reading
greatwhitecracker
Post by greatwhitecracker »
I cant seem to get a boost reading on my predator and after doing some research it seems to be a problem a few other people are having as well. Is there an easy fix for the problem?
RE: lb7 predator-no boost reading
Well, its not really a problem...the Predator only reads what the PCM sees, and the PCM does not monitor boost, so the Predator has no way to display it.
To see boost you need a boost guage.
greatwhitecracker
Oh ok, so when do you ship my boost gauge :wink: :lol:
LBZPWR
Post by LBZPWR »
Yes the ECM does monitor the boost on a LB7, Thats what the boost sensor is for
07 Chevy, LBZ crew cab, LT-2.
Performance Exhaust.
Moto Metal, Skulls
285/70/17" BFG, KO's
Re: RE: lb7 predator-no boost reading
LBZPWR wrote:Yes the ECM does monitor the boost on a LB7, Thats what the boost sensor is for
Thanks, for dropping that enlightening information on us.
Factory boost PIDS will rarely ever read like a mechanical boost gauge though, as they base the boost off of atmospheric pressure, so most factory boost PIDs read 14.7 psi at idle.
LBZPWR
Post by LBZPWR »
No problem!, WOW! My bullydog and edge, read 1ibs boost off factory. But I was just correcting you awnser on the ECM does not read boost, when it does. The ECM delivers fuel based off the boost
Moto Metal, Skulls
GMC04
RE: Re: RE: lb7 predator-no boost reading
Post by GMC04 »
It is better off having a stand alone guage to get a accurate reading to see how hard your turbo is working rather than trying to gather information from the Boost Sensor which only will read up to 22psi of boost on the LB7 engine. I have autometer guage and am pushing 27-28psi of boost with my predator and without the tune installed I was around 21-22psi, more fuel= more boost. Now I do not know the dynamics of what the boost sensor tells the engine but I know there are lots of complaints about programmers displaying only 22psi of max boost on a LB7 engine the answer I keep reading is to get a stand alone guage. I am currently happy with the options and power the predator has to offer do not see the need to show boost levels when it could not show me acurate reading's but that is my own opinion.
2003 GMC Sierra LB7
Banks Big Head Wastegate
MBRP 4"
BD Manifold
Predator
Boost & Pyro
Airdog II
