I have a valve body that flows good and I don't want to increase shift pressure.
When loading the 85 tune, i found lots of trans paramaters. The only thing I changed was the first one, the universal shift pressure. I took it all the way to 0.
Will this keep all shift pressures normal, or do i need to adjust every setting in the predator trans pressures
What options to change for no shift pressure change?
RE: What options to change for no shift pressure change?
That will change the pressures across the board.
Re: RE: What options to change for no shift pressure change?
so if i set that to 0, i dont have to worry about changing any of the other parameters if I don't want an increase in line pressure?mikel wrote:That will change the pressures across the board.
2002 7.3L F250 Crew 4x4
2011 5.0 Mustang GT - [email protected]
RE: Re: RE: What options to change for no shift pressure cha
0 is actually no change from our tune, which has some pressure added, so you may want to play with it to get it where you like it.
mine shifts hard. the valve body works real good all by itself. my tranny guy said to "not' add pressure. trying to make sure thats the way i got it!
thanks
thanks
maybe start with it set to -3 or 4.
