What options to change for no shift pressure change?
beefcake.
Post by beefcake. »
I have a valve body that flows good and I don't want to increase shift pressure.
When loading the 85 tune, i found lots of trans paramaters. The only thing I changed was the first one, the universal shift pressure. I took it all the way to 0.
Will this keep all shift pressures normal, or do i need to adjust every setting in the predator trans pressures
RE: What options to change for no shift pressure change?
That will change the pressures across the board.
beefcake.
Re: RE: What options to change for no shift pressure change?
Post by beefcake. »
mikel wrote:That will change the pressures across the board.
so if i set that to 0, i dont have to worry about changing any of the other parameters if I don't want an increase in line pressure?
2002 7.3L F250 Crew 4x4
2011 5.0 Mustang GT - [email protected]
RE: Re: RE: What options to change for no shift pressure cha
0 is actually no change from our tune, which has some pressure added, so you may want to play with it to get it where you like it.
beefcake.
Post by beefcake. »
mine shifts hard. the valve body works real good all by itself. my tranny guy said to "not' add pressure. trying to make sure thats the way i got it!
thanks
maybe start with it set to -3 or 4.
