mike or johan or mikel
dodge73
Post by dodge73 »
just wondering if i can get a plus 10 tb senstivity?
oh ya its a 2003 dodge ram.. thank you guys very much
RE: mike or johan or mikel
post up your last tune written please.
dodge73
Post by dodge73 »
so performance 91+quick adjust
not sure if you need it....v9r05
and is there any more touching up in the tune?
bottom end wise? thanks for your time great product thank you for supporting the 03..
dodge73
Post by dodge73 »
pcm 56028769af
gizmodo
Post by gizmodo »
Use DSDownloader to pull the last written tune from the Predator and post that here. They will need that to modify.
dodge73
Post by dodge73 »
56028769AF_custom
dude... attach the actual tune file!
click the "post reply" button at the bottom, and then you can attach the actual tune file...
gizmodo
Post by gizmodo »
You have to connect your Predator to your computer, and start DSDownloader. Once there you will see an option to save last written tune. That will put a .drg file on your computer. You have to attach that file to this post.
dodge73
Post by dodge73 »
k sorry
56028769AF_custom (1) (1).drg
(3.25 KiB) Downloaded 166 times
dodge73
Post by dodge73 »
just figured it out
so also i am on v9r05 is there and point in going to the newest crom.. thank you guys
Yes, you should be running 9r09.
dodge73
Post by dodge73 »
so upgraded to 9r09 can i adjust Throttle sensitivity? thanks for you time mike
you will be able to in 9r10.
dodge73
Post by dodge73 »
k thanks for the responce mike keep up the good work =)
white_lightning
Post by white_lightning »
mikel wrote:you will be able to in 9r10.
any trans support for '04 Rams in Crom 9r10?
SC having '04 trans support vs. no trans support for '04 with Diablo got re-visited one more time on HTC:
http://hemitruckclub.infopop.cc/eve/for ... 7361022206
