mike or johan or mikel
just wondering if i can get a plus 10 tb senstivity?
oh ya its a 2003 dodge ram.. thank you guys very much
RE: mike or johan or mikel
post up your last tune written please.
so performance 91+quick adjust
not sure if you need it....v9r05
and is there any more touching up in the tune?
bottom end wise? thanks for your time great product thank you for supporting the 03..
Use DSDownloader to pull the last written tune from the Predator and post that here. They will need that to modify.
dude... attach the actual tune file!
click the "post reply" button at the bottom, and then you can attach the actual tune file...
You have to connect your Predator to your computer, and start DSDownloader. Once there you will see an option to save last written tune. That will put a .drg file on your computer. You have to attach that file to this post.
Yes, you should be running 9r09.
you will be able to in 9r10.
- white_lightning
any trans support for '04 Rams in Crom 9r10?mikel wrote:you will be able to in 9r10.
SC having '04 trans support vs. no trans support for '04 with Diablo got re-visited one more time on HTC:
http://hemitruckclub.infopop.cc/eve/for ... 7361022206
