2010 Ram Hemi Tranny Jumping And Rough
blazingzz wrote:Is this the reason this truck shifts nothing like my 05. There is just no comparison even my dads 05 with 35" tires will bark into second. I just feel this truck is more then capable of it with more power.
Would you like me to post up my last tune written. You could play with the firmness and speed of the trans shifting if you want to give it a go. here is my last tune written anyway just in case. I would appreciate the try even if it is a failure. I just know this truck has more in the shifting areas.
Like I was saying, there is no easy way to add firmness, from what we have found so far.
here is the new tune withmore throttle response added.
1_11_11_ltw_pcm_68059436ab_12_4_10_pcm_68059436ab_perf_blaz68059436ab_throttle.drg
(86.79 KiB) Downloaded 235 times
blazingzz
Post by blazingzz »
Thanks mikel I will download that tonight when i get off work.
Ggreek5
Post by Ggreek5 »
Guys my 2010 ram has only a CAI an mufflex. I have the shudder at wot from 40-50 mph. NO TUNE in the truck. I just ordered a predator. This is not an issue of the tune. It happens to stock rams as well. I can sometimes replicate it and sometimes not.
blazingzz
Post by blazingzz »
i never been able to duplicate it yet personally.... will keep trying of course
dodgeboy
Post by dodgeboy »
I'm in this boat as well. I've just gone back to stock for now, so I can patiently await a fix without worrying about doing damage to the trans/converter. It feels a lot like converter lock-up (or unlock) shudder, to me. But it continues for a disturbing amount of time. Basically as long as you are stabbing the gas (or as long as I've been willing to wait).
Will a datalog help you guys diagnose it? Or does the tool not monitor the necessary trans PIDs to give you the info you need?
I've done an extensive amount of custom tuning/logging with the predator in my SRT8, so I am familiar with all of those aspects of the tool. I will be happy to do anything you need that you think will help get to the bottom of this.
Dave
blazingzz
Post by blazingzz »
Ive had it at stock for two days still no shaking yet. Still going to keep trying to reproduce it with the stock tune.
dboyd1
Post by dboyd1 »
I'm in the same boat, my 2010 has the shutter, would really appreciate a fix. I took it back to stock and no shutter!
'10 1500 Ram Sport 5.7L 4X4 Crew
K&N drop-in, Mufflex DOD14M, DS Predator
Ramathorne
Post by Ramathorne »
What is the latest download for U7137 and can the link be provided....
I have been away from forum for a month or so and feel behind LOL
blazingzz
Post by blazingzz »
Mikel I appreciate the tune with the changes you made for me but I will have the the truck back to stock until there is a change in the shifting. Are you guys still working on this right now or is it on hold till a certain time. If you need someone to test out any changes you make please let me know. I would be more then happy to help make this fix for this as soon as possible.
worlthompson
Post by worlthompson »
You may have a cut or torn 2C or 4C piston seal inside the transmission and it is being agrevated by the tune? We have seen some issues with those two seals. You Tech can diagnose with checking the CVI in the various clutch packs while driving. I am not sure what they should be. drive a known good truck and then drive yours while monitoring the CVI's. Hope this helps
blazingzz
Post by blazingzz »
I am still having no issues stock. I have been running the hell out of my truck for the past week now and still no issues. The only thing I dont like is the sound when the mds kicks in with no muffler. LOL but there is no shaking. Mikel or Johan do you guys have anything else I could try yet any changes. Id be willing to try out some new things here really want this tuner back on the truck. The power difference is pretty noticeable once it is out. Please let me know willing to help here.
klein1j
Post by klein1j »
There was a TSB for JGC Hemi for this exact issue between 40-45 mph. Check out google for this issue on the RAM. Most likley your stock tune has the fix.
Interesting.
klein1j
Post by klein1j »
DS, here is an aticle on a setting called "TCC Break-In". Is this setting set to Disabled in the DS tunes? If not, it needs to be.
A/T - Converter Shudder On Vehicles With Less Than 4K Mi
NUMBER: 21-022-08
GROUP: Transmission
DATE: October 8, 2009
SUBJECT:
Torque Convertor Shudder On Vehicles With Less Then 4000 Miles
OVERVIEW:
This bulletin involves using the StarSCAN(R) to verify that the "Torque Converter Break In" option is disabled (status = false).
MODELS:
2009 (DS) Ram Truck2009 (HB) Durango2009 (JK) Wrangler2009 (KA) Nitro2009 (KA) Nitro (International Markets)2009 (K1) Cherokee (CKD)2009 (KK) Liberty2009 (KK) Liberty (International Markets)2009 (LC) Challenger2009 (LE) 300C/300 Touring (International Markets)2009 (L2) 300 (China)2009 (LX) 300/Magnum/Charger2009 (ND) Dakota
NOTE :This Bulletin applies to DS/JK/LX/LE/LC/HB/KA/KK/K1 and ND models equipped with a 42 RLE transmission (Sales Code DGV) built before September 29, 2008 (0929XX MDH) or L2 models built with a 42 RLE transmission (Sales Code DGV) built before October 10, 2008 (1010XX MDH).
SYMPTOM/CONDITION:
Some customers may experience a shudder condition within the first 4000 miles. This shudder happens during steady state driving with the torque convertor in partial lock while the transmission is still in torque converter break in mode.
The shudder feels like the vehicle is being driven over rumble strips.
DIAGNOSIS:
Using a Scan Tool (StarSCAN(R)) with the appropriate Diagnostic Procedures available in TechCONNECT, verify all engine and transmission Systems are functioning as designed. If DTC's are present record them on the repair order and repair as necessary before proceeding further with this bulletin.
If the above symptom/condition is experienced or can be verified, perform the Repair Procedure.
http://alldatapro.com/alldata/PRO~V1794 ... /139846490
SPECIAL TOOLS / EQUIPMENT REQUIRED:
REPAIR PROCEDURE:
1.Using the StarSCAN(R) select PCM.
2.Read DTC from the PCM.
3.Are any PCM DTC present?
a.No >>> proceed to Step # 4
b.Yes >>> Repair DTC as necessary then proceed to Step # 4
4.Select the "Misc Functions Menu" on the StarSCAN(R).
5.Select the "TCC Break In" option.
6.Select "Start" and the select "Next"
7.Select "View Current TCC Break-In Status"
8.Is the "Torque Converter Break In Complete status False?
a.Yes >>> Using the StarSCAN(R) disable "Torque Converter Break-In"
b.No >>> This bulletin does not apply, further diagnosis is required.
POLICY:
Reimbursable within the provisions of the warranty.
http://alldatapro.com/alldata/PRO~V1794 ... /139846491
TIME ALLOWANCE:
http://alldatapro.com/alldata/PRO~V1794 ... /139846492
FAILURE CODE:
Disclaimer :This bulletin is supplied as technical information only and is not an authorization for repair.
