How to return to stock tune
I have an 07 GT500
I am using the predator U7145
I need to return to stock for dealer visit.
instructions are not clear.
options are
import custom tune
export original backup
export last written
erase custom tune
What do I do??
Thanks Don
options are
import custom tune
export last written
erase custom tune
What do I do??
Thanks Don
RE: How to return to stock tune
don't go into the options...
from the main menu, select Performance Tune...
then one of the choices in there should be "Original Backup"... select that, and it will restore your original backup...
I will try that now.
Don
Don
I did as you said,options were.
diablo tunes
custom tunes
chose custom tunes,reinstalled tune set for myself.
Rebuted and same options came up.
Checked diablo tunes,there is an option at the end for
original backup.
Is this the factory tune??
Don
diablo tunes
custom tunes
original backup.
Don
yes
I will do that now.
Don
I will do that now.
Don
Problem solved.
Thanks.
Don
Thanks.
Don
cool...
np man, you're welcome!
director1203
after restoring the original tune i can then change ECUs and use the Predator on my new ECU correct?
as long as it's a supported pcm for that model predator...
director1203
yes same vehicle. just changing the ECU back to a stage 1 from a stage 2 ECU in my SRT4
How Do I clear out a previous cars Vin number from my Diablosport predator tunner? I put a chip into my mass flow system and made my RPMs go way up to where it should not be will i recalibrate the RPMs?
you can't unlock it... you need to call tech support...
id start by getting rid of whatever chip you put in your MAf...sounds like a recipe for disaster.
