I have a 2005 Crown Victoria (cvpi) using the U7147 programmer.
I bought a cc steering wheel and will be installing it and then taking the car to a ford dealer so that they can enable it.
My question's are, -should i put the stock tune back in before the reflash and then reinstall YOUR tune after the reflash??
Will the cruise control work with your tune after the reflash?
--or should i leave the predator tune in when the pcm is reflashed?
Thanks.
2005 Crown Victoria cruise control question
RE: 2005 Crown Victoria cruise control question
Yes, put the stock tune back before you go, and everything should work fine after you reinstall the tune.
Just got the car reflashed so that cruise control is enabled,but when i try to reload the Diablosport tune i get the message:
"your vehicle is not in our database,contact your dealer for a free update. your cal id is fccnapz"
--im running 9r03
--im running 9r03
Re: RE: 2005 Crown Victoria cruise control question
Go ahead and update the tool to this version and you'll be good to go.Ryder276 wrote:Just got the car reflashed so that cruise control is enabled,but when i try to reload the Diablosport tune i get the message:
--im running 9r03
Enjoy.
- u7147_crown_vic-9t04a.crom
- (782.72 KiB) Downloaded 242 times
RE: Re: RE: 2005 Crown Victoria cruise control question
Thank You! -tune loaded and i will take it for a spin tomorrow.
Sweet.
