2005 Crown Victoria cruise control question
Ryder276
Post by Ryder276 »
I have a 2005 Crown Victoria (cvpi) using the U7147 programmer.
I bought a cc steering wheel and will be installing it and then taking the car to a ford dealer so that they can enable it.
My question's are, -should i put the stock tune back in before the reflash and then reinstall YOUR tune after the reflash??
Will the cruise control work with your tune after the reflash?
--or should i leave the predator tune in when the pcm is reflashed?
Thanks.
RE: 2005 Crown Victoria cruise control question
Yes, put the stock tune back before you go, and everything should work fine after you reinstall the tune.
Ryder276
Post by Ryder276 »
Thanks!
Ryder276
Post by Ryder276 »
Just got the car reflashed so that cruise control is enabled,but when i try to reload the Diablosport tune i get the message:
"your vehicle is not in our database,contact your dealer for a free update. your cal id is fccnapz"
--im running 9r03
Re: RE: 2005 Crown Victoria cruise control question
Ryder276 wrote:Just got the car reflashed so that cruise control is enabled,but when i try to reload the Diablosport tune i get the message:
--im running 9r03
Go ahead and update the tool to this version and you'll be good to go.
Enjoy.
u7147_crown_vic-9t04a.crom
(782.72 KiB) Downloaded 243 times
Ryder276
RE: Re: RE: 2005 Crown Victoria cruise control question
Post by Ryder276 »
Thank You! -tune loaded and i will take it for a spin tomorrow.
Sweet.
Return to “Predator Ford Gas”
