Calibration issues
Lets hope i did this right.
- PCM_639835627570.grg
- stock tune 2011 silverado 6.2
- (67.34 KiB) Downloaded 268 times
This update should work for you11z71 wrote:Lets hope i did this right.
- u7194-9t20a.crom
- (1.25 MiB) Downloaded 274 times
DSDL does not auto launch when you plug in Trinity, you have to open it yourself.
Thats not a trinity crom, thats for Predator.
What is the revision on your tool right now?
options/show information
OK, thats the latest GM CAN GAS crom.
Let me check this out for you.
Ok another question, I figuered I'd play with the modify stock option in tuning until you guys figure out my issue, I know I restored the stock tune to the truck a couple of days ago but when the trinty tries to back up the original it says its a diablo tune,(obviously i screwed something up) luckily I have a good friend at a local dealership that can just reflash the ecm back to stock but my question is if he reflashes the pcm what will i have to do to the trinty to basically reset this thing so when you guys figure out the cal id issue i can use this thing like im supposed too?
if you reinstalled the "factory hp tune" instead, that is considered a diablo tune, NOT the "original backup" stock tune file...
you need to do the "restore original backup" process correctly...
I must've really screwed something up because if I try to restore original back up it says that the original back up is either restored or was never saved, if i go to modify stock tune when it goes to back up original it says its a custom diablo tune. Thats why I asked if the trinty can be reset and I have the truck reflashed If I can start again from scratch.
