predator question.....
liljohn30
Post by liljohn30 »
about 3 weeks ago i was haveing shifting issues with my 08 hemi ram.i returned the pcm to stock and brought it to dodge to figure out wtf..after 3 days trans was fine and all they did was a pcm flash to cure the issue..today i tried to re install the predaotr and i have this saying,,
your calibration is 05094507 AI and is not supported we need to downgrade to 05094507 AH in order to continue..
I dont wanna run into the issue i had before so i need help what is the diference between the 2 and is there a way to utilize the predator with the calibration i have now.What steps do i need to take, i would like to b able to reinstall the flash in the truck now in case of any issues that may arise,mainly i dont wanna downgrade to the other issue and have the shifting issue pop back up again..Help please..................... :?
liljohn30
Post by liljohn30 »
tool says i have version v 9r08
I would update to 9r09 first, then try it again.
liljohn30
Post by liljohn30 »
will do,any explaination as to why it happened
liljohn30
Post by liljohn30 »
i download the new crom 9r09 loaded into tuner and i get the same thing mike
emailed you as newer update to try.
liljohn30
Post by liljohn30 »
figured what i did wrong mike,i never hit the continue buttom,once i did and went to the next screen it made sense.I hooked the tool up to the pc and it automatically did the update,haven't tried to load it in the truck yet ,will keep in touch
liljohn30
Post by liljohn30 »
mike i tried to load ,after about 5 mins of loading and i had to cycle the key a few times it said write failed,make sure key was in on position ,which it was ...reboot was flashing
liljohn30
Post by liljohn30 »
to the top,for an update
liljohn30
Post by liljohn30 »
any info on the ai update from the dealer,i want to use the predator will any of the croms work.if not i will sell the tool its no use to me on my couch
wmfortenberry
Post by wmfortenberry »
I have 2008charger srt and a u7135. It had 9r17 version on it and tried to update to 9r27 but would freeze on 7764 and tool would say unable to save image file. Tried the trouleshoot many times and with no sucess. I finally got one to load but its 9r12 and can't get 9r17 back on it. Need help, dowloaded current files from website. So if I managed to reinstall 9r12 are the 9r17 and 9r27 having issues? Thanks
wmfortenberry wrote:I have 2008charger srt and a u7135. It had 9r17 version on it and tried to update to 9r27 but would freeze on 7764 and tool would say unable to save image file. Tried the trouleshoot many times and with no sucess. I finally got one to load but its 9r12 and can't get 9r17 back on it. Need help, dowloaded current files from website. So if I managed to reinstall 9r12 are the 9r17 and 9r27 having issues? Thanks
If you have an 08, and an older Predator, all you need is 9r12.
wmfortenberry
Thanks, will install now and enjoy.
liljohn30
Post by liljohn30 »
any updates mike
u7137
9t10c
2008 hemi ram
liljohn30
Post by liljohn30 »
any more ideas
