u7137 not working after the upate
i have perdator u7137 rev 9r08 i tried to update the rev to 9r09 but when its come to stage 2 to reboot the device i received mesg in the perdator saying "the application is missing or corrupt."
i need your help i followed the revision update instruction.
RE: u7137 not working after the upate
OK, here is the fix.
click update tool, select 9r09.
power cycle the predator.
Next screen will say tool is ready, do you wish to download, click yes.
NOW, most important part...
On the next screen, that says sending packet 2 of xxxxxx, click cancel, and click the red X and close it out. DSDL will likely go not responding, and crash, thats fine.
At that point, the tool should say 'installing bootloader'. Let it sit like that for about 30 seconds.
Relaunch DSDL, and repeat the update process, without closing anything out this time, and it will go through all the way.
Thanks bro
i did it and its fine i did update my predator.
you have excellent customer service.
all the best
all the best
sweet....
dear
i tried to install the tune to the car but i received this mesg "This vehicle needs an update calid 05094100ai"
need your help
thanks
need your help
thanks
I followed the calibration update steps it was completely installed in the device when I load the update to the car with following the screen steps on the final stage after the update is being installed I got this mesg " The update is not completed".
calid 05094100ai is this Calid supported
Jeep Wrangler 2007
Need your help and support
Jeep Wrangler 2007
any update please
I followed the calibration update steps it was completely installed in the device when I load the update to the car with following the screen steps on the final stage I got this mesg " write failed (failsafe)please make sure the ignition is on and the engine is not running.
calid 05094100al is this Calid supported
Jeep Wrangler 2007
Jeep Wrangler 2007
And this is with 9r09?
Did you cycle the key?
Yes the tool is updated with latest rev 9r09
Yes I followed the tool screen instruction to cycle the key.
we're looking into this guys.
loading 9r09 first is the fix.
