Hello,
OK I now I should have just bought a new one but I got a good deal on a used one, but I dont think it got returned to stock From what I can tell. It has the 8r05 and I wanted to update it and it wont update. Also I noticed the last tune written was Diablo. Can you help I dont want to send it in.
Brent
U7194 used never got returned to stock
- strokethis
Its not what you buy, it what you build.
predator programmer,adjustable HPOP module, Overboost eliminator, intake, 5 inch exhaust, banks wheel, built trans, manual lockup switch, 315's and 100hp sticks. 400hp and 900ft lbs to the ground.
RE: U7194 used never got returned to stock
Needs to be reset, will ne $129.
it is also pretty old, and will not likely be able to be updated to the latest.
- strokethis
Is it still 150 to have the predator updated and unlocked like posted in the header.
$129 for unlock.
BlackZ71Silverado
Sounds like you got ripped off. It's locked to a vehicle and is to old to be updated. Return it and get a new one.
2010 Silverado Ext.Cab 5.3L
MBRP exhaust
AirAid MIT AEM filter
Black bear Performance Tuned
2008 Silverado Ext. Cab 6.0L Vortec Max
GMPP exhaust
GMPP CAI
Black Bear Performance Tuned
MBRP exhaust
GMPP exhaust
GMPP CAI
there is no upgrade program for the 7194 predators... and that old version of it, can only go up to revision 9r08 or 9r10 and that's it - it will not accept/work with the latest new revisions...
search the predator gm gas forum, the 9r08 and 9r10 revision files are posted in it somewhere.... that's as high as you'll be able to go...
and like Mike said, it will be $129 to get it unlocked and reset... you need to call them...
- strokethis
I know I got hosed and I just have to accept that, I may just take the 129 and applly it to a brand new one so that it can be up to date. Thanks for your guys help, the reason I buy DiabloSport is because the support is awsome and the power is great.
Brent
Brent
