2010 Challenger part throttle pinging
duster360
Post by duster360 »
sharkcohen
Post by sharkcohen »
The next time I install it after I get some fresh fuel in the tank I'll gladly post it. But, I would expect it will look like the canned tune on every shipped Predator. If it doesn't, that's a serious problem.
duster360
Post by duster360 »
You don't even have to drive the car to pull the tune off.
Simply flash the 91tune, extract it then restore the Original back up.
Needless Torque Calibrations
www.needlesstorque.com
sharkcohen
Surely it can wait a few more days.
Toyorider
Post by Toyorider »
Dave/Duster360,
Mind taking a look at the logs posted here?
http://diablosport.com/index.php?name=P ... ic&t=25394
Let me know what you see or recommend. i will do some more logging next week with new upgrades to the truck and see if anything has changed.
duster360
Post by duster360 »
Toyorider,,post your 91tune
Toyorider
Post by Toyorider »
the tunes are in the other post and i only ran 87 at the time.
duster360
Post by duster360 »
duster360
Post by duster360 »
Toyorider wrote:the tunes are in the other post and i only ran 87 at the time.
I see them.
I seriously doubt all of the ST knock you're seeing is really detonation.
Long term and Short term Tip-in in spark retard along with Torque managment spark reductions, often show up on the logs as ST Knock Retard.
sharkcohen
duster360 wrote:
sharkcohen wrote:Surely it can wait a few more days.
I could really care less if I ever help you.
I'm not sure I understand the attitude. I do have a life outside of my car. It is simply going to have to wait a few more days. If you can't post anything nice...
duster360
Post by duster360 »
^^nevermind,,,good luck
sharkcohen
Fresh tank of 91, still pinging audibly below 2000 RPM at less than 20% throttle, with STKR shooting up to 14 degrees when I hear it pinging. I'm using the 91 octane canned tune, no adjustments made to it. For what its worth, here's my last written tune. It's just the canned tune file that shipped with the tool.
PCM_68052005AC_Perf_91oct_last_written.drg
(2.25 KiB) Downloaded 177 times
I'm thinking you have a mechanical issue. Theres no way all that knock is being caused by the tune, unless you're using some no name gas, or a crap namebrand. Can you get Exxon, Mobil or BP?
sharkcohen
I filled up with Chevron. There's no knock with the stock tune, so I don't think it is a mechanical problem the car.
