All set.bb1260 wrote:Mike,
Can I please have my tune smoothed as well. 2006 Dodge Magnum R/T stock 5.7. I'm using the U7135 Predator version 9r27.
TIA -bb1260
Smoothing mds
- pcm_04896568al_perf_93oct_smooth.drg
- (47.23 KiB) Downloaded 168 times
Mike,
I was getting some spark knock with the 93 Perf tune (can't always get great gas in my area) and decided to go with the 91 Perf Tune - no problems so far. Any chance you could smooth this one out as well. 2006 Dodge Magnum R/T stock 5.7. I'm using the U7135 Predator version 9r27.
- PCM_04896568AL_Perf_91oct.drg
- (4.25 KiB) Downloaded 138 times
- PCM_04896568AL_012111.drg
- Original
- (55.48 KiB) Downloaded 180 times
all set
- pcm_04896568al_91_smoooth.drg
- (47.24 KiB) Downloaded 123 times
Hey Mike! Can you smooth out mine. I've got U7135 93 performance CAI tune, with revision v.9r12. This is in a 2007 Charger R/T. Thanks.
- 05094804AJ_custom.drg
- (4.25 KiB) Downloaded 114 times
all set.abbottx4 wrote:Hey Mike! Can you smooth out mine. I've got U7135 93 performance CAI tune, with revision v.9r12. This is in a 2007 Charger R/T. Thanks.
- 05094804aj_smoooth.drg
- (59.62 KiB) Downloaded 159 times
No, when you return to stock it fully resets the Predator so you have to re-download the custom tune to use it again.MYPTBUL wrote:Hey Mike! After I installed the mds custom tune, which works fine. When i go back to stock tune for dealer repairs. i notice that the custom tune is no longer in the predator, I have to always redownload it to the predator. Is their anyway to keep it installed.
