Gear swap adjustment 2006 silverado
manny
Post by manny »
I've got a 06 silverado 4.8L with 3.23 gear ratio I'll be changing it to a 3.73 soon. What adjustments do I have to make on my U7192 to make my truck shift properly???
jimmybuckets
RE: Gear swap adjustment 2006 silverado
Post by jimmybuckets »
Is it a 4x4? if it is you have to change both front and rear.
manny
Post by manny »
No its a 2wd automatic. Sorry for not making that clear.
Just adjust the axle ratio parameter in the adjustable parameter menu to correct the speedo.
manny
Post by manny »
Will this adjustment take care of the shift points to. Or do I have to do that seperatly if so what is a good starting point?
Shift points will be separate, as they are based on MPH and RPM, so fix the speedo first.
manny
Post by manny »
Ok once the speedo is set at what MPH do i set the shift points at for each gear?
Return to “Predator GM Gas”
