ok Now I need help!
ok Now I need help!
downloaded the auto shift fix. Updated car, Now when i go around a corner making left hand turn my car from first gear goes into 3rd autoshift won't work i put car into drive and have to pull over turn car off then back on to get autoshift to work again?
emailing the 8t15 revision.
sent...again.
will you also send it to [email protected] Thanks a lot.
Try the new 8r16 revision.
rednug
I just got back from the tuner shop and the tech was only able to get 10 hp from the U7135 w/ 8r14. I have the '06 Charger 5.7L CAI and cat back. The tech said the problem is because I am running 87 octane and I need to come back when I have filled up with 91 octane. I am wondering if I can get a hold of this 8r15 and 8r16 so the tech has more options to play with when I show up next week with 91 in my tank. I thought this predator was supposed to provide 87, 91, and 93 tuning? For give my ignorance, I’m a beginner.
I'm actually surprised you gained 10 rwhp with 87 octane in the tank.rednug wrote:I just got back from the tuner shop and the tech was only able to get 10 hp from the U7135 w/ 8r14. I have the '06 Charger 5.7L CAI and cat back. The tech said the problem is because I am running 87 octane and I need to come back when I have filled up with 91 octane. I am wondering if I can get a hold of this 8r15 and 8r16 so the tech has more options to play with when I show up next week with 91 in my tank. I thought this predator was supposed to provide 87, 91, and 93 tuning? For give my ignorance, I’m a beginner.
The car was probably knocking like crazy.
No performance applications should ever be used with 87 octane if you plan to make any serious power.
ok car went into 3rd again by itself i shifted into neutral then back into drive and the car locked up rear tires almost like i had put it in reverse. almost broke my neck and got rearended. all updates are not stopping this going from going into 2nd and 3rd on it's own and then not responding until car is stopped turned off and then on again! WHAT TO DO NEXT?
OK, please post year/make/model/calid and what changes you have made to the tunes.iceman56 wrote:ok car went into 3rd again by itself i shifted into neutral then back into drive and the car locked up rear tires almost like i had put it in reverse. almost broke my neck and got rearended. all updates are not stopping this going from going into 2nd and 3rd on it's own and then not responding until car is stopped turned off and then on again! WHAT TO DO NEXT?
