Gear swap adjustment 2006 silverado
I've got a 06 silverado 4.8L with 3.23 gear ratio I'll be changing it to a 3.73 soon. What adjustments do I have to make on my U7192 to make my truck shift properly???
jimmybuckets
RE: Gear swap adjustment 2006 silverado
Is it a 4x4? if it is you have to change both front and rear.
No its a 2wd automatic. Sorry for not making that clear.
Just adjust the axle ratio parameter in the adjustable parameter menu to correct the speedo.
Will this adjustment take care of the shift points to. Or do I have to do that seperatly if so what is a good starting point?
Shift points will be separate, as they are based on MPH and RPM, so fix the speedo first.
Ok once the speedo is set at what MPH do i set the shift points at for each gear?
