Mikel...johan could I get some help please
I know the shaking can not be fixed right now with our trucks but is there any way I could get some help with these couple things please.
My truck's idle is still funny. No matter what i set it at, when I come to a stop at a light or stop sign, the idle will drop back down to about 550 rpm until I hit the gas or put some kind or strain on the electronics like winding up the window lol. Then it will jump back to whatever I have it set to and it will stay there till I drive it and stop again.
Also when driving normal around town just at part throttle, the truck shifts as if I am driving a stick. Seems as if there is too much of a delay between the shifts at part throttle. I dont know what the issue is, just know it could be better. Anything you could do for me with either of those in the mean time? Till we get some trucks in for testing with the shaking or get it figured out by dodge if it is there issue. Any help with this would be appreciated. Thanks guys.
- LTW 3-1-11 PCM_68059436AB_Perf_93oct_modified.drg
- (4.25 KiB) Downloaded 173 times
RE: Mikel...johan could I get some help please
hey guys could some take a look at this today, possibly change somethings or do something with it. I am going to be driving my truck this weekend and would be able to try out anything you modify. Any help on this would be better then what it is now. It has horrible shifts and the idle issue is very annoying at a stop. Thanks guys
do you have any changes that would affect the idle on the truck?
there is nothing changed regarding idle in the tune.
just cat back exhaust an cai everone has that though with no issues.
but it dont jump around or anything its just when I come to a stop it drops back down to the stock idle about 550. I have it set 150 i believe above stock and the only way to get it to go back to my set idle is to tap the gas or put some kind of strain on the electronics. Then it will go back to about 700 and stay there till i drive it and come to another stop. Very strange.
But the part throttle shifting is bad also if you could do something with either of those and get it back to me i could test it out this weekend. I would appreciate it thanks mikel
Is it possible that you would have time to do anything do with this today mikel? I know you have a lot of people to worry about on here but im just seeing if you could play with this tune today.
Im really not sure what you are asking man.
Whats bad about part throttle shifting?
Need to be somewhat specific, we cant just make random changes based on your request.
The nose of my truck will drop down in between shift from 1-2 and 2-3. Feels as if im driving a stick. ANy way t get the shifting closer together or firmer shift or more pressure. Im not sure what to fix Im just hoping it can get better then that.
The idle if there is anything to keep it at the set idle at a stop. It will drop down every time. I can even get you a video of that this weekend if that will help. Is there any logging or anything I can do that will help you out in any way let me know. Im just looking for some help.
Maybe monday then?
getting this up towards the top for monday
- white_lightning
try this for the idle issue:
- ltw_3_1_11_pcm_68059436ab_perf_93oct_modified_idle_fix.drg
- (86.62 KiB) Downloaded 147 times
mikel I do have a question about the differences in the transmissions or controlls from my 05 and my 09. I thought they are the same I was just currious as to why mine does not shift very firm now. And there is still a delay between the shifting. My 05 would just bang right into the next gear bark the tires with no problem. This truck has about 50 more hp and the shifting is worse. It does not seam to have as much out of the whole either.
Can you do anything with the shifting with firmness part throttle and wot maybe taking out some tm or something. Also any possibility with the botom end being a little more aggressive.
I have to wait till tomorrow to try out white lightnings tune on my truck. He made an adjustment with the throttle for me. If there is any way to take my last tune and do something with it so I can try them both out tomorrow. Thanks Mikel appreciate any help and any info you give me about the difference from the 05- 09 trans
The trans differences are not something I have too much info on, Johan may be a better source for that info.
