u7146
latest revision
03 mach 1
i'm trying to make some adjustments in the user options.. i keep hearing people talk about adjusting the global spark advance but the only spark advance i see in mine is the 2k-4k and 4k-7k advance.. am i missing something?
not seeing "global spark advance" in my user optio
RE: not seeing "global spark advance" in my user o
not available with the u7146
2003 Mach 1 K&N cai w/screen
Accufab 60mm Twin TB Steeda Tri-ax
Predator custom tune +1 lean 2k-4k, +1 lean 4k-7k
AFR 12.6-12.8 3/8" Roy Spacer IAC plate
Bassani O/R X 2.5 flowtubes to Delta 40's
w/factory tail pipes
Correct, that would only appear on 05+ applications.
ok thank you
