What to expect from Predator?
Toad
Post by Toad »
I just ordered the Predator for my 2007 Wrangler and am curious of what to expect from it? I have a 01 Dodge Cummins with Edge Comp box and Smarty as well as a 03 VW TDI Wagon with Kerma software downloaded. I did a lot of research before deciding on the Predator and hope I will not be dissapointed. Any helpful hints or testimonials for Jeep application would be appreciated!
blazingzz
RE: What to expect from Predator?
Post by blazingzz »
you should be satisfied with whatever they make for your vehicle. They always have great throttle response, performance options and performance numbers. It wount be any gain as it was for your dodge cummins, but you should be happy with your results.
Toad
Post by Toad »
thanks blazingzz...throttle response is one of the main things I am after. The Jeep has a throttle spacer on it as well as non-stock exhaust. I ordered the Predator and AFE cai to help with throttle response and fuel economy and also calibrate speedometer for non-stock tire size. This is my first venture into any gas engine tuning and I am way to excited to get my hands on the Predator and start playing with it!
blazingzz
Post by blazingzz »
you will be happy but just dont expect a huge power gain. It will more then likely be more then any other brand though. You will definitly gain throttle response. The tuner usually works well with cai and aftermarket exhaust. The ability to change the tire size is great also.
