I perfomred the new update on the Trinity. When I went to load my Custom Tune back into my vehicle the Trinity stated I needed a Calibration update. At that point I connected the Trinity back to my pc and the calibration update ran auotmatically. Now my custom tune does not match the calibration.
The file did end in af and now ends in AH. I believe the Custom Tune will need to be made compatibale with the new calibration.
Or is it possible to reload the older software version back into the Trinity ?
I have attached my Custom tune and the new calibration just in case they will be of some help.
Any assistance is appreciated since the car has a Vortech I cannot drive it until this is resolved.
Programmer: Trinity - Lastest Update
Vehicle: 09-Challenger R/T Auto with Vortech SC.
Thanks !
New Update and Calibration - Tune needs update
- 05187912af_toon_001.drg
- custom tune
- (73.93 KiB) Downloaded 120 times
- PCM_05187912AH.drg
- new calibration
- (88.3 KiB) Downloaded 106 times
RE: New Update and Calibration - Tune needs update
Same thing happened to me man as the Cal ID has changed. Basically send the New Original backup you just downloaded from your Trinity and send it to your Tuner. Your tuner will then have to resend your current tunes that you are using based on the New original backup you have now.
That's what I was afraid of.Knuckles wrote:Same thing happened to me man as the Cal ID has changed. Basically send the New Original backup you just downloaded from your Trinity and send it to your Tuner. Your tuner will then have to resend your current tunes that you are using based on the New original backup you have now.
Do you know if it is possible to reinstall the older software into the Trinity?
Here you go man.
- pcm_05187912ah_toon_001.drg
- (74.06 KiB) Downloaded 112 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
