9r20 on U7194 causes failure when backing up OEM tune
bocass
Post by bocass »
I upgraded my predator from 9R14 to 9R20. Does not allow me to save original tune when trying to load diablo tune. Causes the ecm to throw stabiltrack errors and car wont start. clearing codes allows car to start but will not save original tune and fails.
I then used 9R19 and everything works fine. I have inquired about this in another post but received no response from support. Called tech support and after 15 minutes spoke to a tech who was very short on the phone, didnt let me finish what i was saying,cut me off and was very condesending. He seemed under great pressure to answer calls quickly and move on to the next call. His solution was to send the tuner back. I am not adverse to this but seems to me that if several people are having the same problem with an update that the issue resides with the update. Does Diablo keep the diferent hardware iterations of the predator on hand and when a new update is pushed out it is first tested? If R19 works fine but R20 fails the backup of the original wouldnt that be key information to see if the coding is bad in that area? Also I live locally( within 5 miles) but was told you dont allow walk ins.
I am not getting a good feeling about Diablo support.
Your phone support needs much to be desired
Your web site recommends using the forum but you dont respond to posts.
You dont allow walk ins. (no sense of urgency to fix the users issue)
Sems like the solution is to "send it in" even after several people have complained about the same thing.
Your product works great when it works. But having spent good money on it I expect better support.
BlackCamaro6,2
RE: 9r20 on U7194 causes failure when backing up OEM tune
Post by BlackCamaro6,2 »
Hi, greetings from Germany !
At first : sorry my english is not perfect.
Some Camaro 2010 driver in Europe have same problems with the 9R20 Update.
Symptoms the same as bocass discribes !
These are the DTC`s the PCM sets : codes: p0606, p0607, u0101, u0109, u0121, u0140
Predator shows : backup not saved(-11) an he tried again with the same result
After that i "reupdate " the predator to r19 i have no problems to flash the PCM
with the Diablo-Tune ( 93 oct ).
I think you have a bug in your update !
For the future it make sense to have a update archive with older versions !
Please be so kind and think about that.
Best wishes !
bocass
Post by bocass »
Thanks for posting that you are having the same issue blackCamaro6,2.
P.S. Must be nice driving the 5th gen on the autobahn!
BlackCamaro6,2
Re: RE: 9r20 on U7194 causes failure when backing up OEM tun
bocass wrote:P.S. Must be nice driving the 5th gen on the autobahn!
Yes :D especially with : Speed Limiter Off => 165 mp/h
Fix is here, please update to 9r21
BlackCamaro6,2
Thank you !
By the way, can you tell a little bit more about this Update, especially for
the 2010 Camaro SS/RS L99 ?
did you try the new revision fix? did it work?
BlackCamaro6,2
06MonteSS wrote:did you try the new revision fix? did it work?
Sorry, not yet, it`s bad weather in Germany an the Camaro is only
for driving in sunshine.
Maybe on saturday, i can give you a feedback.
I hope, user bocass can test it earlier.
BlackCamaro6,2
UPDATE
I try it ( u7194-9t21a.crom) , but sorry, it does not work
Same DTC`s set as before.
Please try again for 2010 Camaro L99.
Good Luck !
BlackCamaro6,2
mikel wrote:
BlackCamaro6,2 wrote:UPDATE
Good Luck !
I try 21b, but same DTC`s set as in 20 and 21a.
and "....No backup (-11)"
I flashed car back to 19 this works perfect.
Good Luck !
can you post your VIN and calids please?
Good Luck !
OK, try this please:
u7194-9t21c.crom
(1.41 MiB) Downloaded 222 times
BlackCamaro6,2
2G1FK1EJ0A9119033
Car was shipped to Germany in November 2010, before shipping the
dealer updates the car :
#09207A: Service Update for Inventory and Customer
Vehicles - HVAC Reprogram, Engine Harness Position
Inspection, Rear Spoiler Fasteners - (Sep 23, 2009)
this must be the last update.
In Germany - at the moment - nobody can update the Camaro,
because GM starts selling the Camaro in Europe not until Sept. 2011.
Maybe you can see something in GM`s -TIS :
http://tis2web.service.gm.com/tis2web
Thank You
edit :
oh, i see you have version c ! I try it today.
thanks, let me know about the c update.
BlackCamaro6,2
It works !!! Great !!!
No problems with the Predator and the Tune.
Smooth running engine ! Perfect !
...and here some impressions ( i hope no mental delusion )
- better throttle response
- improved transmission/shifting
Thank you for my Version !
Have a nice weekend Image
