2009 Charger/U7135/9r28
Just got back from datalogging at cruising speed and one 0-60 run. While cruising at 45mph ST KR was between 1.500 and 2.500. It spiked up to 4.500 for about a second then came back down. I know MDS kicks in while cruising at 45mph with light pedal pressure. The log also showed LT KR at 2.500.
Is this normal?
The 0-60 run showed only 1.000 ST KR at 4400rpm. This was in second gear. When the car shifted from 1st the rpms dropped to 3600rpm and as the revs climbed the was zero ST KR until 4400rpm. It dropped to .500 before I let of the throttle.
I just switched to the 93 tune from the 93 CAI tune since I had re-installed the stock airbox and removed the aFe CAI.
Thanks.
Will MDS show KR?
RE: Will MDS show KR?
there is some knock on the ram hemi trucks. just search part throttle knock/ping/kr. i dont believe they fixed it in the last crom but i havent done any datalogging yet to see....
Yes, 05+ HEMI Rams have MDS.
The predator tune has more timing than stock?
