I'm gonna blow this transmission sky high before I replace it.
Is there a 9r28l?
Is there a 9r28l?
Mike? I wanna play with the throttle booster. Is there an "l" version of 9r28 yet? Stuck with 9r12 for now because of the stupid memory issue (can't it be repartitioned to allow more CROM space and less logging space?).
RE: Is there a 9r28l?
already sent it....
mjf6866
mikel, can you please clarify if the booster is available in the one on the download page?
and why isnt the "l" version found on the download page?
throttle booster is in 9r28, yes.
mjf6866
thanks for the response Mike...can you confirm if it will work in my 6-speed?
also, what is the difference between the "l" version and the regular 9r28?
thanks again
thanks again
No, throttle booster is an auto only thing, sorry.
Re: RE: Is there a 9r28l?
l version is a shorter version that goes with the older predators because they have less memory space.mjf6866 wrote:thanks for the response Mike..
thanks again
Bigsnake
10 Charger SRT8
11 Mustang Shelby GT500
10 Charger SRT8
RE: Re: RE: Is there a 9r28l?
can i get a 28l too,older predator 2007 for 2009 charger srt thanks,,,,
2009 Charger SRT,91 tune 180 thermo
I got it from Mike Licht. I have Win7 too and it saved fine. When you click Download, you should get a window with choices of Find, Save or Cancel. Hit Save. You'll get a prompt for what to save it under and where. Pick the place you want it, leave the filename as is. Save As type should be CROM file. Hit Save and it should download to where you just put it.
