boost gauge does not work after updating to the 1r08 crom.
I have a 2003 Pt Cruiser Gt. boost gauge worked fine on the trinity before i updated to the 1r08 crom now it stays at 0 boost so i updated it agiin and it still not working. anyone have any ideas? please help.
RE: boost gauge does not work after updating to the 1r08 cro
Can you try monitoring MAP and BARO. What do they show?
Yes they work. baro 96.60 map reads around 32.80 .
With BARO=96.6 kPa and MAP=32.8 kPa; The Boost Synth PID will be 0.
Boost only shows > 0 when MAP > BARO.
yes that was at idle map changes a lot when driving. just don not understand why boost synth worked fine before and when i updated it quit. i also tried making a new gauge layout with a synth boost gauge and still not working all the other gauges seen to work fine.
map goes >baro just went and checked
can you log that and post it?
You did it right. Your log is showing BARO and "READ MAP kpa" non-standard PIDs which were used to calculate Boost for early SRT4 ECUs. In the more recent DCX Gas 1R08, we switched to using standard PID's which don't work on early CalIDs. It's something that needs to get fixed in next DCX GAS release.
- BoostedSRT4
- Flakdodger
fix is here:
- trinity_dcx_gas-1t08aa_update.crom
- (2.4 MiB) Downloaded 513 times
Thanks for the feedback.
