THROWING CODE P0128
chuckster
THROWING CODE P0128
Post by chuckster »
I am throwing code P0128 on my 2008 5.7 R/T Charger AFTER I installed a 180* Jet thermostat. I am using the 93 CAI canned tune from my 7135 Predator.
I have reset the code but it keeps coming back..... The temps are good and fans have been set to proper "lower" settings, basically everything checks out good.
Any suggestions or updates?[/b]
bigsnake
Re: THROWING CODE P0128
Post by bigsnake »
chuckster wrote:I am throwing code P0128 on my 2008 5.7 R/T Charger AFTER I installed a 180* Jet thermostat. I am using the 93 CAI canned tune from my 7135 Predator.
Sounds to me like you are not giving your car a chance to warm up after starting.
P0128
This means that the engine's PCM detected that the engine has not reached the required temperature level within a specified amount of time after starting the engine. The intent of the P0128 code is to indicate a faulty thermostat. Similar codes: P0125
In determining the engine did not reach a "normal" temperature, it takes into account the length of time the vehicle has been running, the intake air temperature (IAT) sensor reading, the engine coolant temperature (ECT) sensor reading, and the speed of the vehicle.
Bigsnake
10 Charger SRT8
11 Mustang Shelby GT500
RE: Re: THROWING CODE P0128
This can be fixed in a custom tune, post up your last tune written please?
chuckster
Post by chuckster »
Mikel, Thanks for the reply! Last tune written was V.9r27
brandy16
Post by brandy16 »
He means the last tune written from the predator. Download the last tune written and post it here. He will fix it and post the new tune here for you to down load on to your predator.
chuckster
Post by chuckster »
Here is my latest tune.
PCM_05094985AG_Perf_CAI_93oct_modified.drg
(4.25 KiB) Downloaded 171 times
chuckster
Post by chuckster »
Mikel, Any progress about fixing this P0128 code issue? I posted my tune on 3-16-11.
chuckster
Post by chuckster »
Anything??
chuckster wrote:Anything??
all set...
pcm_05094985ag_perf_cai_statfix.drg
(59.85 KiB) Downloaded 160 times
FAhemiST
Re: RE: Re: THROWING CODE P0128
Post by FAhemiST »
mikel wrote:This can be fixed in a custom tune, post up your last tune written please?
out of curiosity, 'fixed' meaning you turn the code off for good, or is there something you actually change?
RE: Re: RE: Re: THROWING CODE P0128
fixed , as in changed when it runs the P0128 test.
