ETA
white_lightning
Re: RE: Re: RE: ETA
Post by white_lightning »
TooCoolHemi wrote:I select the modifed stock tune,don't think you get tcm option's when selecting your proformance tranny tune.
you should be able to modify the shift points on the Diablo performance TCM tune too. I tried it, worked on my truck.
just looked with CMR to confirm, Diablo performance trans tune has stock shift points, so if you have shift points that you like, you should be able to use "modify tune" add them in.
TooCoolHemi
RE: Re: RE: Re: RE: ETA
Post by TooCoolHemi »
If the performance tune has stock shift point's then what's changed in it? Mike? Well now that i have figured out how to get the tcm option to show up i can check it out.I remembered asking the above question when i upgrade but got no response.Mike can you please tell us what is differant than stock in the Performance trans. tune? At least what we should expect from selecting this option.
TooCoolHemi
Mike,please respond.
FAhemiST
Re: RE: Re: RE: ETA
Post by FAhemiST »
TooCoolHemi wrote:But deceided to try Chris's suggestion to wiggle it.This did not help
LOL and i thought for sure that would work for ya
TooCoolHemi
lolol But your suggestion did help lead me to find a solution.
TooCoolHemi
I guess you don't know?Johan,Can you help us out here?
