U7146 Revision Update / Tweak
Dubie
Post by Dubie »
Sup,
After updating to newest revision 9r09 from I think 7r50d.
Which afterwards my buddy was like hmm I think we did something wrong.
I went to site to see if I could find any info on getting logs to my laptop.
Then I ran across the update revision install guide and seen it said "Load factory tune first to car."
Since I was just updating more or less to see if that fixed my issue with backups failing I did not do this step.
This is what we did wrong. lol
When I called support the other day and the first guy I talked to wanted me to plug in my predator and check out some info and stuff before I freaked out. hehe
I had to call back tho because I was not able to hook it up right then.
When I called back today I think I talked to someone else.
He did not ask me to hook up the predator to check anything, he just sent me an old revision 7.50d to try and downgrade my predator.
Now I really want to know what the first guy was going to have me check out the other day. lmao
I will downgrade it and try to load my factory tune back to my car and see if it works.
Did not know if there was anything else I can try first before trying to downgrade.
2nd guy I talked with said "if after downgrading it and it does not restore my factory tune I would have to have a factory reset on my car and DiabloSport would have to reset the predator.
Trying/Hoping it does not come to this. ;)
(Question)
Can I try to restore my factory tune first before downgrading my predator.
I mean will it hurt anything trying that first, It will either work or say it failed, right?
If restoring my factory tune works I have a couple questions to try and help me fix/get my current tune back.
Steps going to take:
1.) Downgrade my predator back to revision 7r50d.
2.) Restore factory tune back on my car.
3.) Then update Predator back to revision 9r09.
4.) Then I will try to retune my car back to what it is now.
That should be all I need to do I think.
(Questions)
I installed 410 gears and they had to tweak my tune for the spadomiter "speedometer" to be correct.
1.) What will I need to change for the gears/spadomiter to be in sync again?
2.) I also had new "Underdrive Pulleys" installed so will I also need to make any changes for that being installed as well?
I am new to tuning my car so just wanted to ask others that have "been there done that before".
Any help would be greatly appreciated.
Thanks for your time,
Dubie
Predator: U1746
Software: v9r09
Mustang GT 2003
Dubie
RE: U7146 Revision Update / Tweak
Post by Dubie »
FYI: Friend of mine has the same make/model/year/predator.
The same day I updated my predator we did his as well from 7r50d -> 9r09 w/o putting factory tune back on car first by mistake.
He was able to put his factory tune back on and use the DiabloSport Performance Tune for 93o.
So all looks fine.
He will tweak the tune some to make sure it's all working but ya so far so good.
Will be doing mine tomorrow to see how it turns out. hehe
Peace.
Return to “Predator Ford Gas”
