02 mustang gt w/procharger & mafia
MAF.i.a Support
lm11m
Post by lm11m »
Should maf reading on scanner with koeo be same as stock parameter .6-1 volt ? Mine's reading 5.12 and running poorly. Need info asap . Thanks
RE: 02 mustang gt w/procharger & mafia
its a 0-5 V sensor, you should not be seeing that much voltage.
What does it look like at idle?
Do you have a MAFia installed?
lm11m
Post by lm11m »
Yes, MAFia is installed. If I take out of system car will idle normally
no, that wont help, you need it there if the tune is set up for it.
Id rma the mafia if voltage is not right at idle.
lm11m
Post by lm11m »
what's your procedure,
bought car with unit installed
Return to “MAF.i.a”
