Overdrive jumping in and out also very sluggish takeoff
I have a 2006 Dodge Durango Limited running the 93 Octane Performance Tune. I cannot get to the transmission settings and the overdrive is jumping in and out constantly. I had transmission checked and all checked out perfect. Also it is very sluggish out of the gate but from bout 45 mph or higher all kinds of power. Can anyone help? Oh and my fuel economy went from 18 to 11.5 from 9r10 when I went to 9r11... I would like it to shift harder but the overdrive thing Im not sure what is going on there.
- Lohr2-PCM_05094075AK_Perf_93oct_modified.drg
- Latest tune
- (4.25 KiB) Downloaded 365 times
behindbars1544
RE: Overdrive jumping in and out also very sluggish takeoff
I got a 2006 charger R/T 5.7 thats doing the same thing. Damm thing is driving me crazy. Almost feels like the T/C keeps locking and unlocking...
Apparently our problem isnt very important... I am going to call Summit and return my programmer and purchase the bully dog tuner.
jtpredator
its a weekend, give the guys a break
It was posted March 16th... Figure a half of a month is sufficient amount of time to respond....
I see March 30....either way, sorry.
I reply to about 100 posts a day, I occasionally may miss one
Sounds like it may be MDS kicking in and out, try turning it off to see, and if so, I'll make you a new tune with the MDS smoothed.
I have MDS off. Ive tried it both ways. I just changed my plugs to Bosch Iradium and it got worse. not sure what else to try.
Just thought I'd chime in here. On my 5.7L 2008 Grand Cherokee I noticed since 9r10 that the MDS is very noticeable when engaging and disengaging. Maybe make a note for the next release to smooth it out for everyone if that's possible. I have seen a couple different posts with people commenting on this issue with MDS.
Damn bosch plugs cost me 7.99 each x 16 plugs ouch... Ill go NGK soon... Mike, my tune is posted above can you fix it up for me? I guess MDS smoothing and low speed/take off improvement please... Thank you guys for the pointers.
Re: RE: Overdrive jumping in and out also very sluggish take
copper plugs FTW!jay.lohr wrote:Damn bosch plugs cost me 7.99 each x 16 plugs ouch... Ill go NGK soon... Mike, my tune is posted above can you fix it up for me? I guess MDS smoothing and low speed/take off improvement please... Thank you guys for the pointers.
Here you go...
- lohr2_pcm_05094075ak_perf_93oct_smoooth.drg
- (46.02 KiB) Downloaded 334 times
RE: Re: RE: Overdrive jumping in and out also very sluggish
Mike, What all did you change on that custom tune? And is there a link on how to get the new tune on the predator? Thanks
Re: RE: Re: RE: Overdrive jumping in and out also very slugg
smoothed the MDS.jay.lohr wrote:Mike, What all did you change on that custom tune? And is there a link on how to get the new tune on the predator? Thanks
- Hemi custom tune instructions.doc
- (35.5 KiB) Downloaded 324 times
RE: Re: RE: Re: RE: Overdrive jumping in and out also very s
ok im installing now... any suggestions on take off being sluggish?
thanks mike
thanks mike
better gas?
I run 93 octane and Lucas Octane booster every tank of gas. I have the throttle setting at +15%
