u7136 - V6 Challenger 2010
I just got my predator and it was already 9r07.
The car said I needed to update the Cal so I started that process with the DS Downloader and each time it freezes and says:
"there was a failure sending the update to the tool. Is the tools firmware up to date?"
The crom is up to date...I even reinstalled the 9r07 crom from the website with no problems then went to the car...again needs new CAL.
Tried the CAL process again still freezes....
Any ideas? Is it having a problem downloading the new CAL from the net???
Thanks...
can't update CAL to tuner - V6 Challenger
andyboydinomon
RE: can
what is the calid in the vehicle currently?
andyboydinomon
RE: can
the car is currently 68054128AD...it says that when it tells me I need an update also when I go to troubleshooting/current car cal id...
thanks for quick response...
RE: can
OK, do this:
1. Download this file: http://www.diablosport.com/downloads/drg/68054128ae.drg
2. Save it as 'local.drg' in the same directory that you installed DS Downloader to.
3. Execute DS Downloader, click the Calibration Update button.
4. The update should succeed with none of the error messages you saw before.
5. Delete the 'local.drg' file to make sure that it does not interfere with any future updates.
Re: RE: can
use the attached local.drg file.mikel wrote:OK, do this:
- local.drg
- (489.01 KiB) Downloaded 155 times
andyboydinomon
RE: Re: RE: can
Followed instructions with the attached file. It still seems like it tries to download the file during the cal update and freezes. How do I specify the new local.drg file???/ or does it happen automatically?
RE: Re: RE: can
if the local.drg is in the right place, it wil grab that file before it goes to our server for a file.
(C:\Program Files\DiabloSport\DSDownloader)
andyboydinomon
RE: Re: RE: can
got it working! thanks for your help...
RE: Re: RE: can
good deal.
