#s to enter in Trinity to log AFR w/ Autometer wideband ???
SRT8_in_CT
Can anyone tell me the exact high and low values to enter into the Trinity for an Autometer wideband? It's been trial and error so far, and I got it close, but would like it perfect if possible..I don't know where to find the #'s .. Anybody logging AFR w/ an Autometer??
Thanks in advance..
Ken
Thanks in advance..
Ken
SRT8_in_CT
RE: #s to enter in Trinity to log AFR w/ Autometer wideband
BTW.. It's in a 2006 Charger SRT8 with a 6.1 ... brand new Trinity w/ latest software
SRT8_in_CT
Well, I went from bad to worse.. In searching I came across a "good" thread, so I reset to default and entered new parameters.. Now all I have is volts where before I had AFR readings... Arghhh
The default analog input is in Volts. In the same analog configuration, You can "Add" a new input specifying your upper and lower values. The label and units can be whatever you want.
SRT8_in_CT
Re: RE: #s to enter in Trinity to log AFR w/ Autometer wideb
Thanks ... I can't seem to get to that add new input part.. This is what I did...jimb wrote:The default analog input is in Volts. In the same analog configuration, You can "Add" a new input specifying your upper and lower values. The label and units can be whatever you want.
Trinity input range is 0-5v. Your autometer is 0v == 15.1 AFR, 4v == 10.1 AFR (Please check it's not 0 == 10.1 and 4v == 15.1).
Do the following:
- Options -> Analog Input Config -> Reset All defaults. (Start fresh)
- Options -> Analog Input Config -> Add a New Parameter.
- Enter a Name (e.g. "My AFR")
- Select the analog input chanel. (1 or 2 depending which wires you used. see: http://www.diablosport.com/index.php?na ... 14&start=0)
- Change Units. (It defaults to "Volts". Change it to "AFR" or anything you want using the '<' button)
- Enter Lower Bound: 15.1 ( maps to 0v)
- Enter Upper Bound: 8.75 ( maps to 5v)
I can't figure out how the '<' button works? It just erases volts on the screen.
SRT8_in_CT
SRT8_in_CT wrote:Thanks ... I can't seem to get to that add new input part.. This is what I did...jimb wrote:The default analog input is in Volts. In the same analog configuration, You can "Add" a new input specifying your upper and lower values. The label and units can be whatever you want.
Do the following:
So is there a drop down menu somewhere to select AFR instead of the default Volts? If I use the '<' button I can erase volts and type in AFR, but it still displays in volts ..
What am I missing, gotta be something stupid?
Thanks in advance
RE: Re: RE: #s to enter in Trinity to log AFR w/ Autometer w
That's the backspace button. Delete the word volts and type AFR.
SRT8_in_CT
Re: RE: Re: RE: #s to enter in Trinity to log AFR w/ Automet
Exactly what I did, but still displayed in Volts .. I will try again from scratch today.. Thank yougizmodo wrote:That's the backspace button. Delete the word volts and type AFR.
RE: Re: RE: Re: RE: #s to enter in Trinity to log AFR w/ Aut
Did you select your new analog pid when creating the dashboard?
SRT8_in_CT
Re: RE: Re: RE: Re: RE: #s to enter in Trinity to log AFR w/
I think that's where I went wrong.. Started again from scratch and finally got the AFR on the autometer gauge super close on the Trinity ..gizmodo wrote:Did you select your new analog pid when creating the dashboard?
However, when I entered the following #'s from a post above it was nowhere close...
I wound up experimenting and settled with 10.0 as the lower bound, and 17.5 as the upper.. I'm now within .05 to .1 difference between the Autometer AFR gauge and what's showing on the Trinity.. Pretty close ..
Thanks for the help
alittletippy
RE: Re: RE: Re: RE: Re: RE: #s to enter in Trinity to log AF
srt8 you had it backward with the previous settings. you are right with what you did at the end of your last post. Lower boundry is just that, the lower limit of your reading and upper boundry is upper limit. I use a autometer wideband in my srt4, but i cant remember my settings. your settings look close.
SRT8_in_CT
Re: RE: Re: RE: Re: RE: Re: RE: #s to enter in Trinity to lo
Agreed .. I was going on the post by jimb ..alittletippy wrote:srt8 you had it backward with the previous settings. you are right with what you did at the end of your last post. Lower boundry is just that, the lower limit of your reading and upper boundry is upper limit. I use a autometer wideband in my srt4, but i cant remember my settings. your settings look close.
Do the following:
I wound up with 10.0 low and 17.5 high and shot a video and when I stop it, it's real close ...
yes,you can find it.SRT8_in_CT wrote:BTW.. It's in a 2006 Charger SRT8 with a 6.1 ... brand new Trinity w/ latest software
SRT8_in_CT
Find what? Would you care to elaborate? Thanksmckwre wrote:yes,you can find it.SRT8_in_CT wrote:BTW.. It's in a 2006 Charger SRT8 with a 6.1 ... brand new Trinity w/ latest software
