2001 Dodge 5.9 Cummins will it fit or not?
chandler
Post by chandler »
2001 Ram 3500 5.9 cummins "6" series engine. Sort of worked up a blind deal with a guy who needed something I had no use for and he, likewise. It is a Diablo Sport Tunable Power Puck with 8 allen set screws around the perimeter equally spaced, not in groups of twos. No numbers. Only connection resembles the 98.5-2000, which hooks directly up to the VP44 connector. On one cable is the Diablo logo with 1-WAY03486. Will it fit a 2001, and if not, what does it fit? Thanks for listening to my ramble.
RE: 2001 Dodge 5.9 Cummins will it fit or not?
Tough to say, but if the connector is right for 98.5-00, it should be a D7153.
http://www.shopatron.com/products/produ ... 61.0.0.0.0
chandler
Post by chandler »
Thanks for the response. Yeah, that is what I gathered from your website and the pictures. So, even if it has the right connectors for the VP44, would I damage the Vp by plugging it in, or do I need all the other wiring as shown for the 7154?
chandler
Post by chandler »
OK, maybe an easier question for the manufacturer. What is the difference between the D7153 and D7154, besides the extra harnesses? Engines are the same. Are there embellishments on the 7154 that may or may not be needed or required?
Ideally they were simply different connectors to my knowledge.
chandler
Post by chandler »
Thanks for the assurance. I hooked it up and it does seem to make the engine a little more peppy, more smoke on upshifting. We'll see about the fuel mileage. Thanks again for the help.
