Can't download logs
General Trinity Support
jimb
RE: Can
Post by jimb »
Are you saying when you don't save the dash layout and proceed to log, it works? Whereas creating/saving a dash layout and attempting to log with it, errors occur?
gizmodo
RE: Can
Post by gizmodo »
That's what Duster reported. I never tried it. I was able to get the layout to work by reducing the number of PIDS from 30 to about 23. That was with saving and viewing in monitoring mode.
GeeTeePT
RE: Can
Post by GeeTeePT »
jimb ..AFR re-calibrated and DV works ...
gizmodo and Duster...did the layout setup and started logging per your suggestion and part way through was prompted to save the layout and log which I did. Ran a second log and all was fine. Logs also downloaded to DV . The work around did the job.
Thanks and credit to you guys for all your help. Wish I could buy you guys a beer or 2 or 10 ...
Now on to my next Q's but that is another topic about Surge and the 93 tune... will post it on Thursday night.
05PT GT. Limited Trim. K&N CAI. Needswings 3" O2 & Downpipe & High Flow CAT to 2.5" Magnaflow exhaust. Plastic manifold.Trinity 93 oct tune. Dual pod pillar with AM Sport Comp boost and Innovate AFR wideband gauges. S1 PCM & injectors.
GeeTeePT
RE: Can
Post by GeeTeePT »
Ok ...so error messages are starting to pop up again on the new layout. Logs for awhile and then prompts " Do you want to save the recorded log". Worked ok for about 3 days then started with the same ol' stuff.
Will try re doing it.
GeeTeePT
RE: Can
Post by GeeTeePT »
OK ...this is something that should be remedied in the next update. Still getting the error message.
Return to “General Trinity”
