New Jeep features, new Ram HEMI tunes!
This test crom has new Jeep Wrangler specific features including:
Lock diffs at any time (4 low/high) (Rubicon only)
High idle
On the fly idle adjustment
There are also new tunes for all HEMI Rams to improve performance and shift feel, as well as smoother MDS transitions.
All calibrations, including manual trans, will now have the throttle booster option as well.
Tire pressure threshold adjustment can now be lowered to all the way to 0 psi as well.
let us know how you like it!!
High idle
- u7137-9t12c.crom
- (2.86 MiB) Downloaded 261 times
RE: New Jeep features, new Ram HEMI tunes!
No luck on the tire size adjustments for the GC ?
just downloaded. ill let you know how i like it as soon as i get the chance to loade it up!!!
2008 5.7L Ram 1500 QC*Spartan Plus cam* Ported Heads*LT headers*E-Fan*Custom Tune*and 4.56s out back* 341rwhp/341rwtq with 105 ambient air temp!
Mike is it written so that the same upgrades apply to the Jeep GC? (performance, shifts and smoother MDS)
2006 300C-SRT
185 T-Stat/Catch Can
DiabloToona CMR Gas tune
Extra "Flex" E-85 tune
Re: RE: New Jeep features, new Ram HEMI tunes!
The Jeep features are Wrangler specific...DGatzby1 wrote:Mike is it written so that the same upgrades apply to the Jeep GC? (performance, shifts and smoother MDS)
RE: Re: RE: New Jeep features, new Ram HEMI tunes!
just took the truck for a spin with the new update, and let me tell you mike, you guys did a great job. the shifts are more refined, the mds transistion is hella smoother. and it feels like it pulls harder. i have yet to try the mpg tune tho. keep up the great work!
Awesome feedback sir, much appreciated!
Any possibility or plans to do the same for the Grand Cherokees for the final release? MDS being the biggest issue which were almost identical to the problems the RAM boys were having.
MDS smoothing should be done in all tunes now....load it up and let us know how you like it!
Sweet! Will do...thanks.
Bump for some more feedback!
Loaded it up in the GC last night. The "clunk" as we called the MDS engage/disengage was gone! Performance seemed good but that is hard to see improvements in without a timer. Shifts did feel a bit more firm. I would say it is a nice upgrade, thanks guys!
2006 300C-SRT
Loaded up tune yesterday and finally have drivability on highway without the surges & rpm jumps at steady speed. The truck jumps to life now off the line as it should without the sluggish feel it had on the newer tunes. After using the tune again today, i definitely think the shifting is better, firmer.
The ONLY complaint i have left (for over a year now) is the fact that overdrive kicks in at around 38 mph and drops the rpm to around 1250 (approx) which makes the transmission buck n shudder. I can turn off overdrive or speed up to over 45 mph and the problem goes away. If there is any way you can make overdrive not kick in until after 45 mph or have rpm's after overdrive kicks in over 1400, then i believe the problem would be gone.
Overall Great improvement on the Tune!
A+ Improvements!
2006 QC 4x4 5.7L
CAI / Fan Delete / 170 Deg F Stat
93 Oct BP Gas / 93 Perf Tune 9r12a (test)
A+ Improvements!
2006 QC 4x4 5.7L
- airportdave
drfeelgood
