What should I enter for fan temp settings
ayeaye
Post by ayeaye »
does anyone know the stock fan settings on the 06 Charger SRT8?
I entered
180 for LS fan
205 for MS fan
220 for HS fan
I am on CAI perf 91 oct setting stock tstat
Mike
06 Charger SRT8 Red loaded....Drive Moonshine5 Rims/Airaid CAI/Diablo Predator tune
guidosrt8
fan
Post by guidosrt8 »
that sounds right for stock stat if you do a 180 i would use 180-190-205
k9289
Post by k9289 »
Mike question:
07 R/T 5.7
Are these good settings with just a CAI, 180 Stat and Catback? Using 93+CAI tune
180 LS
190 MS
205 HS
ayeaye
Post by ayeaye »
thanks guiodosrt
Mike
copracer288
Post by copracer288 »
The fan settings are already adjusted for a 180 stat in the canned tune.
Turning on the LS fan at 180 might cause it to run too much.
When cruising on the highway I run between 183 - 185 with the 180 stat. The canned tune has the LS fan coming on at 190.
Rob
'07 Charger SRT8, black
Gone but not forgotten: '04 STi & '01 Camaro SS
Life Member: Veterans of Foreign Wars
Scottwoos06RT
Post by Scottwoos06RT »
Hmm...
Got mine set to 184, 187 and 192.... no idea if it's right or not, but car is staying cool and the fans are cycling
I have mine set on whatever it came with, but the fans are running constantly. Really annoying. Whats the highest temp that can be used to turn them on?
christina
Post by christina »
If you would like to set it to stock settings, you can go into Modify Stock Tune and it will show you what it is at stock.
Christy High
lurker.
BUZ-CCC
Post by BUZ-CCC »
christina wrote:If you would like to set it to stock settings, you can go into Modify Stock Tune and it will show you what it is at stock.
If Diablo set fan for 180 stat at 190 low 199 high I would think you could set fans at 213 low 222 high as stock stat is 203degrees this would give you the same spread that they used. Stock settings are real high 219 low 226 high.
