can not find throttle boost setting in tool
After doing a performance 93CAI tune with a u7135 & with a 9r28, I want to modify the throttle boot setting but cannot find it in the tool, all I can see under modify tune menu is dyno, tire size & trans. Any help would be great, thanks
RE: can not find throttle boost setting in tool
Automatic?
What is your calibration ID?
Hi Mikel, found a menu map for 8r17 on the forum, do you have one for 9r28? thanks
same place, in the modify tune menu after you select the tune.
