What does Diablo recommend on Fan settings for 180 t-stat
screech
Post by screech »
U7135/ 9r27/ SRT-8 2009 Challenger w/ 93 cai tune.
RE: What does Diablo recommend on Fan settings for 180 t-sta
lower them all by 20*.
Ciyoung
Post by Ciyoung »
Hey, Mike.... What about a 2009 Challenger RT?
Trinity #6JS9AC2-1 / pt# dcx_gas / Ver# 1r08
2009 Dodge Challenger RT (Perf CAI 93oct + Quick Adjust)
Same answer ;)
Ciyoung
Post by Ciyoung »
rdrdr90
Post by rdrdr90 »
Not to beat a dead horse....lower by 20*....different answer for Texas Summers? Hasn't been below 100 in a while, just want o be sure I don't burn out a fan motor. Thanks!
fordomatic69
Post by fordomatic69 »
If you are lowering your thermostat by 20, then you should be lowering your fans by 20 regardless of the Air temperature.
Fordomatic Says:
"I've heard of Vaporware... but I've never actually seen it" :lol:
http://www.twincamlubricants.com - For all your synthetic lubricant needs. Order Online and save over retail.
HalsMag
Fan settings
Post by HalsMag »
I haven't found a 180 thermo that starts opening at 180 in my vehicle - they all open at 186 and operate at 188-190 best case..Per Chrysler tech. the radiator is only designed to keep the coolant at 100 above ambient anyway. Running in the 190's to low 200's is fine, unless you're racing and need to keep out of heat soak.
2006 Mag R/T 05/05 build
AFE2, 383 stroker, Inertia ported 6.1 heads, SRT shorties, high flow cats, Solo cat back.
Zeitronics W/B, Builder bill Flex plate, TC and Trans.
