Transfer DSH file to TDS file
Is it possible to transfer .dsh file (data viewer dashboard) into .tds (trinity layout) file to monitor more parameter directly on the trinity. For exemple i can monitor transmission oil temperature with pc and data viewer connect to the car both not with the trinity only. This is for a 2009 hemi ram.
RE: Transfer DSH file to TDS file
No....they are different types of files entirely.
Is it possible to had some pid to monitor for exemple transmission oil temp directly on trinity.
Why I can monitor transmission oil temp with data viewer and PC but not with trinity.
When using DV, it uses it's own PID database. Whereas Trinity contains only a compiled sub-set of PIDs.
Do you know if the transmission oil temp and other pid will be add in the list or if a program will be create to modify this database on the trinity by the user.
