Brakes lights come on after tire size is put in
The part # u7194
Revision is v.9r22
The vechicle is a 2007 chevy silverodo pick up
The tire size is 265/70R17
The problem that I am having is that after installing the modified tune for the correct tire size 31.5" and the performance tune the trucks warning lights for the brakes and abs system comes on . So far no one at Diablosport can come up with a correct answer to the problem.
Should I just return the programmer and buy someone elses????
Help, Vension
[/b]
Revision is v.9r22
Help, Vension
[/b]
RE: Brakes lights come on after tire size is put in
Im having the same issue!!! Still havent found a answer yet.
Are you also disabling the speed limiter when you do this?
My traction control light comes on, when I make a turn, and I could feel the front brakes come on, the computer think s its slipping
07chevyvortecmax
I have the same issue, I have an 07 vortecmax 6.0L chev. Put on both the 87 and diablo tune. Never set my tire size until I read some forums. Since I'm a mechanic I put on my Solus pro Snap-on scanner and my front speed sensors were at 103 kmh and the rear sensors were at 112kmh. The abs code is a C0245. I then re-installled the tune with the 275/55R20 tire size and went for a drive with the same result. I did have the max speed turned off on the second tune. Upon re-installing the stock tune all my speed sensors were at 107kmh.
SO DID TO SOLVE THE PROBLEM,? WHAT CAN I DO
try leaving the speed limiter ON for now.
My brake light and ABS light are both on after tuning and tire adjustment. any fix yet?
post up backup and last tune written please
87 tune, modified tire size to 285/70/17
I need the actual tune file as exported formt he Predator.
Re: RE: Brakes lights come on after tire size is put in
I am having the same issue. In a previous thread, Mikel said it was an issue with lifted trucks that there is no fix for.steveb wrote:My traction control light comes on, when I make a turn, and I could feel the front brakes come on, the computer think s its slipping
2010 Chevy 6.2L
K&N CAI
6" RCD lift w/35" Nitto Grapplers
K&N CAI
RE: Re: RE: Brakes lights come on after tire size is put in
Lots of people have the same problem with trucks that aren't lifted.
Re: RE: Re: RE: Brakes lights come on after tire size is put
My point exactly. I find it hard to believe that the lifted trucks and non-lifted trucks have seperate issues when they are doing the exact same thing.2008Silvy wrote:Lots of people have the same problem with trucks that aren't lifted.
2010 Chevy 6.2L
K&N CAI
K&N CAI
blackout07
RE: Re: RE: Re: RE: Brakes lights come on after tire size is
My truck is lifted with 35's and 4.88 gears and I have no lights.
