Octane Range of 93 Octane Diablosport Performance Tune?
MustangSTL
Post by MustangSTL »
Mike, I know that the stock tune in the 2011 Mustang V6 will handle fuel from 87 Octane to 93 Octane by adjusting the timing - advancing timing or pulling timing back. Ford makes the statement that they can get additional horsepower, out of the stock tune, with 93 Octane fuel.
Can you tell me what is the "Octane range" of the Diablosport 93 Octane Performance Tune? Can the tune pull enough timing to keep 87 Octane fuel from pre-detonating?
RE: Octane Range of 93 Octane Diablosport Performance Tune?
Thats not a good idea at all, if you want to run 87, use the 87 octane tune :)
MustangSTL
Re: RE: Octane Range of 93 Octane Diablosport Performance Tu
mikel wrote:Thats not a good idea at all, if you want to run 87, use the 87 octane tune :)
Mike, can you tell me if the 2011 Mustang V6 Diablosport 87 Octane Tune or the 2011 Mustang V6 Diablosport 93 Octane tune uses the "knock sensors," in the 2011 V6 block, to retard timing if you get the wrong grade of gas at a gas station?
RE: Re: RE: Octane Range of 93 Octane Diablosport Performanc
yes, they are still there and active.
MustangSTL
Mike,
One more question - and thanks very much for all your help! My Trinity says it currently has Ford_can_gas 1t08ae 03/25/2011 .
Is there a newer version of Ford_can_gas out? I got an indication of a new loader 2.2.2.6 and I downloaded it. However, when I go to UPDATE TOOL I don't get any indication there is a new update. Does that mean I have the latest Ford_can_gas CROM?
yes, 1r08a is the latest.
if you register your trinity, it will update it to all of the latest updates automagically.
MustangSTL
Mike,
Thanks for the informaiton. Do I have to flash my car back to stock before I check for and download any new CROM releases - ie. a new Ford_can_gas?
Yes, you must restore the stock tune prior to updating.
Return to “Trinity Ford Gas”
